Re: Boring 413 to 426 ???
[Re: R70RUNNER]
#169999
12/20/09 04:00 AM
12/20/09 04:00 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
It's starting again someone picked this 413 thread out the trash from a YEAR ago.... If we're going to drag ALL the 413 threads back out AGAIN... Mods can we PLEASE have the :horse: smiley back
Someone alert the usual 413 cheering section... here we go again
It seems that every time there is factual info placed on the board about 413's, some people get very nervous and frustrated. I guess some people cannot relate to Mopar BB with less than 4 1/4" bore. It is not a putdown, it's simply an observation. "Runner", the post was simply a true statement, given by the R&D Engineers from Chrysler, who were also pro racers. These honorable men were the basis of the 413/426 Superstock/Max-Wedge program. They were known as THE RAMCHARGERS. Honestly without them, the Big Block program in the later years would not have been as STRONG as it continues to be. Lighten up man, and learn a little more. There is more to posting besides .
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: dodge_nut]
#170001
12/20/09 04:52 AM
12/20/09 04:52 AM
HYPER8oSoNic
Desert Tracker
its amazing that useful knowledge is actually provided and transferred.. i mean with everyone thinking they are smarter than the other person.
i, for one, know i am not smarter than a lot of people. i can respect everyones knowledge, but couldnt you all just have ended this thread with this:
the 413 can be bored to the 426 specs, but you have to sonic test it to ensure there is no undesired core shift.
boom.. the thread can end.
It IS NOT the point of everyone thinking they are smarter than others. We are all trying to "share" information. To learn from one another opens up new ideas in ways to make more power and run better times, maybe get a better deal on parts. You never know. And I, do not think that I am smarter than the next person. If I have useful, factual knowledge, I try to share it with those who are willing to listen and research also. If they have info. then I would listen and research on the topic also. Nobody knows everything, and if they did they would not be mortal.
[Re: MonGoo$e]
#170002
12/20/09 05:04 AM
12/20/09 05:04 AM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Me thimks so.
You spelled "thinks" wrong. Not cool to bust on people for spelling when you can't spell on your own. You also failed at capitalizing some letters elsewhere in your reply. But I'm just messing with you all. What's spelling have to do with knowledge of an engine?
Hey Goo$e ...who rattled yurr cage ? ..
That misspelling ? ...was done on purpose. "Proper" English would be .... I think so. Same/same as my spelling of the word that I use for BETTER ... best-er.
JUST a style of writing.
Now to be ON TOPIC ... take a tip from guys who know-more about 413 and 426 blocks than ALL OF US .. put together...
Talk to any stock-eliminator guy who runs the 413 or 426 motor .... they all go with the motor home/truck block ......
BECAUSE it is BESTer !
[Re: HYPER8oSoNic]
#170004
12/20/09 12:11 PM
12/20/09 12:11 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Isn't an 8 bolt flange considered akin to the HEMI mill.
Yes, but the early 383RB's and 413's also had an 8 bolt flange, they earned the slang name "413 truck cranks" some time ago but that's not an accurate description as they were in passenger car 413's as well. They were about 3/8" longer at the flange than later 440 or Hemi cranks, they bolted directly to the converter and used no flex plate. They could bolt into a later engine, but the flange extended back too far to use with a late model flex plate & converter. When I built my 1960 413 engine (original 300F Long Ram engine) I swapped the crank to a later 6 bolt so that I could run a 1965 727 behind it.
[Re: 70Cuda383]
#170005
12/20/09 12:14 PM
12/20/09 12:14 PM
HYPER8oSoNic
Desert Tracker
I always thought the rule of thumb was .060 is the safe limit, anything beyond that, sonic check it.
of course, never say never, if you sonic check is first, then you'll always be safe
Very good point! Know before you punch the block. Best way. Or play the safe route, but $$$$, hone and put custom pistons (4.18) in it. Owners choice. Or, even safer up the ante and run a 440 block. Lots of options here!!
[Re: HYPER8oSoNic]
#170010
12/25/09 10:26 AM
12/25/09 10:26 AM
dOc !
Florida STAYcation
As for the they have their place and refuse to learn from others. Don't waste your posts on them.
But HYPER ... it is sooooo much fun giving-'em a JAB and a wake-up-call from time-to-time !
Merri Xmas to all ... even the 413 haters ! JUST SEND ME all those reject parts ... I will put them to good use ...down-the-road !
[Re: bonefish]
#170012
01/01/10 12:03 PM
01/01/10 12:03 PM
HYPER8oSoNic
Desert Tracker
Somewhere I have in writing stated by the "real" Larry Sheppard,retired Chrysler Staff Engineer who was responsible for the early Direct Connection Performance Manual that the only 413 block that can be "safely" bored to 426 is the 62/early 63 Max wedge and medium duty truck block.It can and has been done with others but you are taking a chance."If" I can find it,I'll post it.However,I'm sure there are still experts here that will dispute it.
Just to let you know that there is only one Larry Sheppard, so you do not need to refer to him as the "real one".
actually if you google LARRY SHEPPARD youll find that there are thousands of them(i can only suspect that most of them are imposters)
Ah Er Um, the "key words" in the post were retired Chrysler Staff Engineer, in case you didn't get it. That's what makes him the "real" one. I do believe that most of us knew who was referred to in the post. I don't think that the ones that were "googled", have anything to do with the post so unless you are trying to be funny, save the jokes, please. However, if you can provide some useful info, we will definitely pay attention!
