Boring 413 to 426 ???
#169959
12/18/08 12:59 PM
12/18/08 12:59 PM
Posts: 2,535 God's Country Maryland
GODSCOUNTRY340
I've got a '64 413 HP block and was wondering how many of you have bored your 413 out to a 426 cid, any problems? Thanks.
Re: Boring 413 to 426 ???
[Re: 62maxwgn]
#169962
12/18/08 01:55 PM
12/18/08 01:55 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Truck block yes,standard 413 no unless its Max Wedge block.You need to bore .125,thats 1/8",too much in my opinion.Not saying it can't be done but I wouldn't do it.
I don't know where you got your math but when I went to school 4.18 from 4.25 was .070. To answer the question Many 413's were bored to 426 spec's long before sonic checking was heard of and lived.
[Re: MoparforLife]
#169963
12/18/08 01:59 PM
12/18/08 01:59 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
If you were as old as I,maybe you would forget.You bore yours at what you want and I'll do the same.
[Re: MoparforLife]
#169968
12/18/08 05:16 PM
12/18/08 05:16 PM
62maxwgn
Blair County,PA
Very likely as old or older. Was there & twisting wrenches when these engines were pretty common.
I was there before they made them !
[Re: Supercuda]
#169971
12/18/08 06:50 PM
12/18/08 06:50 PM
62maxwgn
Blair County,PA
Then you must of forgotten that a .060 over 413 is only .010" smaller than a stock bore 426.
Ran plently of .060" over 413's with no issues and another .010" will not make a difference.
BTW, an eighth of an inch is .125".
and two times that makes a quarter.
[Re: ScottSmith_Harms]
#169972
12/18/08 07:59 PM
12/18/08 07:59 PM
Posts: 3,616 Riverside, Ca
G_bob
Riverside, Ca
Yes, as long as it passes the sonic check you shouldn't have problems with most blocks, I have one that I had bored to 426 (1959 casting date passenger car block) and it passed the sonic check with flying colors, no problems, the thinnest spot was 170 AFTER it was bored, most mearurements were still over 200.
Agreed. I have a 61 413 block that sonic checked THICK. We're boring it to 426 size and putting it in my wife's 64 fury. Walls are so thick, it could even be bored to 440 size and still be ok.
[Re: G_bob]
#169973
12/18/08 09:41 PM
12/18/08 09:41 PM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
If you are using the crank that came with the block I suppose you are using the 61 transmission also.Otherwise it wont work with the 62 and later 727.
#169977
12/19/08 01:28 PM
12/19/08 01:28 PM
G_bob
Riverside, Ca
You might luck out and have a 6 bolt crank/aluminum 727, look at the rear flange and count the bolt holes in the crank and you'll know for sure.
Confirmed, 6 bolt crank, still in great shape. Just needs polished and standard bearings.
[Re: MoparforLife]
#169978
12/18/09 09:52 PM
12/18/09 09:52 PM
well your bore spec is wrong. 413 have a 4.1875" bore so a .0625 over is required. but the smart ones bore it .060 and then finish hone it to each piston. bore it .070" over + hone and your gonna have problems. also when it comes to cylinder block thickness, there is no difference between the truck/industrial/ or passenger car engine.
