Re: holley jet size 35?
[Re: Cab_Burge]
#1697519
11/11/14 06:43 PM
11/11/14 06:43 PM
Posts: 2,141 junction city oregon
viperblue72
Holley marks there jets with a flow number, not a inner diameter
I am still confused with this number. My trick has been getting terrible mileage. I believe the carb should have either a #56 or size 56 can't remember. This is a 1968 carburetor so I just wonder if they numbered the jets differently back then? It can't be a size 35 can it?
[Re: viperblue72]
#1697520
11/11/14 06:46 PM
11/11/14 06:46 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Maybe it's a mis stamped 53?
Had a similar issue with my 72 swinger's 225. turned out the reman carb had a jet 6 numbers bigger than stock. Bought the right jet and things were all good. Mine was supposed to be a #50 IIRC.
[Re: Supercuda]
#1697521
11/11/14 07:11 PM
11/11/14 07:11 PM
viperblue72
That was my thoughts too. Maybe stamped backwards.
[Re: 62maxwgn]
#1697525
11/11/14 08:27 PM
11/11/14 08:27 PM
RapidRobert
What's going on with the mileage? what eng yr make model gears timing choke recent work, everything. Recent issue or always there. What MPG
[Re: RapidRobert]
#1697526
11/11/14 08:30 PM
11/11/14 08:30 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
That "#35" jet looks closer to a #85.
And it looks more like a Carter jet, Holley stamps jet #s on the side, not the face.
[Re: RapidRobert]
#1697528
11/12/14 02:59 PM
11/12/14 02:59 PM
viperblue72
The truck is a '81 2wd slant 6 auto. It has the lean burn on it. The vacuum pot wasn't working. I replaced the distributor yesterday for one with vacuum advance that's actually working. I also rebuilt the carburetor, but the carb seemed ok. The gears seem to be likely 3.55s. I was getting 11 mpg. Hopefully these changes will help. I have an msd 6al that's going on it as well. I may just order a jet, so that I know what's in it. I don't have drill bits that small.
[Re: viperblue72]
#1697529
11/12/14 06:06 PM
11/12/14 06:06 PM
RapidRobert
OK so you have a 68 stand alone (non lean burn) carb & a good vac adv dist. other than the std tune up issues: compression check/no vac leaks/ballpark timing/good plugs/wires etc as you said you might order some bigger jets & good point the guy mentioned that Holly jets are stamped on the side (at least the ones in my white plastic holley jet box are). Oreillys is pretty good about ordering run of the mill speed parts & could probably get some jets in for you. Not sure which company sells them individually but I've seen em. You might get a 40-50-60 & do some experimenting. Holler how things go
[Re: viperblue72]
#1697531
11/12/14 10:37 PM
11/12/14 10:37 PM
RapidRobert
To clarify: it got 14mpg with the carter and the NOS dist installed then ONLY the carb was switched to the holley (same dist) & the mileage went downhill?. Same ported or non ported for the can? I'm assuming there is a good reason why you dont put the carter back on there. those 1920's are so simple/fun to work with. I would wanna get to the bottom of it just for the satisfaction. I'd get some jets and recheck the float (level/saturation)/no base gasket or vac line leak. Holler how it turns out. not sure the 35 is right & I have one & I'll see if I can pull the bowl & see what jet is in it (not sure what year it is) but what I have outa tell us something. EDIT reread & saw the "terribly". describe that
[Re: RapidRobert]
#1697532
11/12/14 11:11 PM
11/12/14 11:11 PM
viperblue72
Robert that's correct, only changed the carburetor to begin with. The Carter was remanned and was very wore out. I also prefer the simplicity of a holley. I ordered a #53 that I will compare and put in. Not sure what you mean by ported or non ported can. I will also report back if the distributor change fixes it.
[Re: viperblue72]
#1697533
11/12/14 11:21 PM
11/12/14 11:21 PM
RapidRobert
"ported/non ported" was the vac can plumbed to the ported (likely) base nipple on both carbs (no vac to the can at idle). Stay in touch with this. EDIT Did it take alot more throttle with the holley than it did with the carter to get the same amount of accelleration?
[Re: B5 Bee]
#1697535
11/12/14 11:58 PM
11/12/14 11:58 PM
Posts: 15,377 Omaha Ne
TJP
Omaha Ne
I'll disagree. I have a buttload of holley jets from the 70's & 80's, All stamped on the face
[Re: viperblue72]
#1697537
11/18/14 10:36 AM
11/18/14 10:36 AM
Supercuda
About to go away
About to go away
up yours
Pretty sure a #53 or a #56 jet is too fat. My 72 225 ran a #50 stock.
[Re: viperblue72]
#1697539
11/18/14 02:56 PM
11/18/14 02:56 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I can't update mpg yet. But with these changes my top speed went from 78mph to 85mph. I'll update mpg soon. I also installed a #56 jet. It appears smaller than what was in it.
Out of curiosity what what is the actual carb number ?
[Re: 62maxwgn]
#1697540
11/18/14 04:30 PM
11/18/14 04:30 PM
viperblue72
I don't have the carb number now, but I did look the numbers up and it was out of a '68 dodge pickup. I have not been able to find anywhere stock jet sizes were listed. I got the #56 from a guy on the net, so it's not necessarily right.
[Re: dogdays]
#1697541
11/18/14 04:32 PM
11/18/14 04:32 PM
viperblue72
Just from looking at the picture I can tell you your old jet was at least a 72.
You may be able to go smaller one or two jet sizes from stock, maybe more depending on your altitude. I'd start reducing jet size until you get lean surging at cruise, then go up one number. Holley says you have to make a two number switch to have a noticeable change, but on such a small carb I'd go one step increments.
I have bought jets on the 'bay but I have found a local place that'll sell me a pair of jets for $4.00. Some are new, some used...but unless some donkey messed with the holes, they work.
Another area where one can make the engine work better is ignition advance curve. Unless you have a problem with detonation, bringing it in faster will add some snap to the engine's performance.
R.
With the new distributor, I did have to back the timing off just a bit due to detonation. Now that the vacuum advance is working.
[Re: viperblue72]
#1697543
11/18/14 05:01 PM
11/18/14 05:01 PM
Supercuda
About to go away
About to go away
up yours
My suggested #50 jet was based on the 72 Dodge FSM's listing for a 72 Swinger with a 225, which is what I had. That carb had a #56 in it and got horrible mileage.
[Re: 62maxwgn]
#1697546
11/18/14 07:26 PM
11/18/14 07:26 PM
viperblue72
Bill, Thank you for looking that up for me. I will probably downsize my jetting to stock, and go down a size or two from there if possible. Fwiw it was listed as a '68 automatic pickup. Is there anywhere I can find this kind of information on the internet?
[Re: 62maxwgn]
#1697547
11/18/14 07:29 PM
11/18/14 07:29 PM
Supercuda
About to go away
About to go away
up yours
There you go, better data.
[Re: viperblue72]
#1697549
11/18/14 08:50 PM
11/18/14 08:50 PM
Supercuda
About to go away
About to go away
up yours
Hey, no sweat, I didn't know the specs for a 68 truck and I couldn't find anything on the net, so I gave you the specs I had as a starting point. As long as it works out in the end that's all that matters. My Swinger was a CA emissions car so who knows how that might affect it.
[Re: Supercuda]
#1697550
11/18/14 10:31 PM
11/18/14 10:31 PM
RapidRobert
Viper that ain't a long winded post! I went & checked my Holley jet box & was surprised that they start at 64 from the numbers in this thread that are way lower
[Re: RapidRobert]
#1697551
11/18/14 11:14 PM
11/18/14 11:14 PM
62maxwgn
Blair County,PA
That's because that box is the performance jetting,not applicable to one and two barrel carbs.You'll find those jets all have the number stamped on the side.
[Re: RapidRobert]
#1697553
11/19/14 12:37 AM
11/19/14 12:37 AM
viperblue72
Oh Ok that makes sense
Yeah, but thanks for sharing, as I was just looking at prices for those assortment kits earlier and considering one. I have to order jets online as the local parts stores aren't carrying holley jets like they used to.
