Re: Master Cylender
[Re: TOMRR]
#1697090
11/10/14 05:34 PM
11/10/14 05:34 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
There is a O ring inside the master the rod goes into.They can be a bear.You can put the rod end in a vice and smack the plunger off.Make sure the new master has the Oring or a piece of vacuum hose so the rod cant fall off.Rocky
Chrysler Firepower
Re: Master Cylender
[Re: TOMRR]
#1697093
11/10/14 11:11 PM
11/10/14 11:11 PM
RapidRobert
I'm assuming you are replacing the MC. FYI next time leave the allen bolt in the MC rear flange holding the piston in place, in there & clamp the MC in your vice & slip a rod thru the end of the pushrod & hit the rod with a hammer at a straight angle close to the eyelet to drive/pull the other end of the pushrod straight back out of the MC piston. If your hyd floor jack has a hole in the plate/correct dimentions to set the MC/pushrod verticaldown into it then slip a rod under the jack horizontle thru the eyelet then jack it up (the even pressure works much better) to seperate em
