Page 3 of 3 1 2 3
Re: The future of Carbs?? [Re: gregsdart] #1696195
11/14/14 10:18 AM
11/14/14 10:18 AM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Do you guys think that someone will ever come up with a nitro carburetor?
I believe they did in the 1950s; Stromberg two barrels and a big drill bit for jetting
Oh, lets not forget the first fuel pump that could keep up; a pirated aircraft hand pump of some sort Garlits mounted so he could work it on the run!
I believe the top speed went from 150 mph to 80 mph with the addition of that pump
Did it not work well? You never hear anything about people running carbureted nitro. Or even trying it.
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: The future of Carbs?? [Re: 1320Dart] #1696196
11/14/14 10:01 PM
11/14/14 10:01 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
The only problem with a nitro carb might be if it backfires it makes a mushroom cloud and blows engine shrapnel (including you)200 yards
Try it Now!!!
WIZE
In Car:
Re: The future of Carbs?? [Re: Streetwize] #1696197
11/17/14 09:36 AM
11/17/14 09:36 AM
gregsdart Offline
gregsdart  Offline
Try it Now!!!
Nitro reacts a bit like C4 explosive. You can burn a little bit and heat your beans and weenies; but Lord help you if you put a lot of pressure on it. The burn rate goes to 300,000 ft/ sec
On the use of the hand pump, I am sure it was a cobble together test to see what would happen. Once the results came in, time for a big electric pump
Re: The future of Carbs?? [Re: gregsdart] #1696198
11/17/14 01:05 PM
11/17/14 01:05 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
$2500?????????? That's a lot of beans,twice what I paid for 2 SV1's.I hope to have EFI someday,but it's still expensive for the system I would need.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Page 3 of 3 1 2 3
