5/16 vs 3/8 fuel line, fuel pump and return #169581
12/17/08 09:52 PM
12/17/08 09:52 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
I will be installing my 410 sb stroker into a 96 Dakota. The fuel line on it now is a 5/16, since this engine is a street engine, should I used the larger 3/8 fuel line? Also will a stock pump be sufficiant enough, and should I run a return line?
thanks
Re: 5/16 vs 3/8 fuel line, fuel pump and return [Re: Dakota_Don] #169582
12/17/08 10:48 PM
12/17/08 10:48 PM
5/16/stock pump will be fine. I'd wait on adding a return line to see if you have any vapor lock problems.
Re: 5/16 vs 3/8 fuel line, fuel pump and return [Re: RapidRobert] #169583
12/17/08 11:29 PM
12/17/08 11:29 PM
Alton, IL
Alton, IL
thanks again
Re: 5/16 vs 3/8 fuel line, fuel pump and return [Re: Dakota_Don] #169584
12/18/08 02:37 PM
12/18/08 02:37 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Put the 3/8 line on it, especially if running a mechanical pump.
5/16 might get fuel to it, will it be in sufficient quantities to maintain optimal performance?
Want to do a fun test. Run the 3/8 line on the truck, but don't hook it up, seal both ends. Put in the 3/8 tank sender, hooked to the 5/16 line. Run it at the track. Hook the lines up to the 3/8 line and run it again.
I've had and worked on cars that were running pretty well. Swapping from a 5/16 to a 3/8 line gained in some cases up to .25 in the 1/4.
Re: 5/16 vs 3/8 fuel line, fuel pump and return [Re: RobX4406] #169585
12/18/08 05:15 PM
12/18/08 05:15 PM
Alton, IL
Alton, IL
I might do that since i want to drop the tank anyway..and i do have 3/8 alu line..
Re: 5/16 vs 3/8 fuel line, fuel pump and return [Re: Dakota_Don] #169586
12/18/08 06:22 PM
12/18/08 06:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd keep steel line on it if it's for the street. I think 5/16" line will be fine with a stock pump for the street.
If it's a race truck...maybe.
5/16" steel line is a heck of a lot safer than 3/8" aluminum for the street. IMO
