upper control arm bushings #169540
12/17/08 09:12 PM
12/17/08 09:12 PM
tennessee
P
pushbutton Offline OP
P
tennessee
Anybody know the o.d. of upper a arm bushings for a 64 Polara. I,m having trouble pressing them in. They seem to be about 3/16" larger than the opening. Need some advice,or tricks of the trade.
Re: upper control arm bushings [Re: pushbutton] #169541
12/17/08 11:35 PM
12/17/08 11:35 PM
scratchnfotraction Offline
I put mine in the freezer over night and then lube em up and they go in a lot easy-er
may double check to make sure they are the right part #
I freeze the lower ball joint before knocking them in also
Re: upper control arm bushings [Re: pushbutton] #169542
12/17/08 11:54 PM
12/17/08 11:54 PM
wrong ones
Re: upper control arm bushings [Re: RapidRobert] #169543
12/18/08 12:37 AM
12/18/08 12:37 AM
tennessee
P
P
tennessee
[ quote]wrong ones They came in a kit from PST,also had a set of older perfect circle ones that were the same size. checked with local NAPA theirs were the same. does anybody know the correct measurement or part number. Is 64 polara same as other 62-65 B bodies?
Re: upper control arm bushings [Re: pushbutton] #169544
12/18/08 01:22 AM
12/18/08 01:22 AM
I do not have a part #/measurement for you as I do not know B bodies & I am just going by the 3/16" dimentional difference that you have which is way too much for the freezing/heating trick to work
Re: upper control arm bushings [Re: RapidRobert] #169545
12/18/08 11:11 AM
12/18/08 11:11 AM
tennessee
P
P
tennessee
I figured out what i was doing wrong. Dumb mistake. I've rebuilt two front ends on my other cars, but always had ft end shop press bushings out and in. Oh well i'll know the next time.May tell whole story later on dumb things i've done post. lol thanks for the replies.
Re: upper control arm bushings [Re: pushbutton] #169546
12/18/08 11:12 AM
12/18/08 11:12 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Were the bushing sleeves still in the arms?
Re: upper control arm bushings [Re: bobby66] #169547
12/18/08 02:25 PM
12/18/08 02:25 PM
tennessee
P
P
tennessee
You got that right,got to looking for the old ones this morning,and thought you big dummy there still in there. You can't beleve how much better the new ones fit after i got all of the old ones out. Ailgnment shop had done that part for me before,so i'd never seen a control arm with the bushings out. Never get to old to learn.
