727 trans question #1694832
11/05/14 05:37 PM
11/05/14 05:37 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
Will a 383 727 fit a 440?
Thanks in advance
Re: 727 trans question [Re: 5carguy] #1694833
11/05/14 05:41 PM
11/05/14 05:41 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Yes
Re: 727 trans question [Re: 5carguy] #1694834
11/05/14 05:41 PM
11/05/14 05:41 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
Should. What year trans and motor? You know in 67 they changed from the 19 spline output shaft to the 23 spline in the tranny.
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: 727 trans question [Re: KingTuna] #1694835
11/05/14 09:40 PM
11/05/14 09:40 PM
Locomotion Offline
Locomotion  Offline
Did 727's always have the larger converter snout and big blocks have the corresponding larger register in the crank?
Small blocks had small versions as well as spline difference from 1967 & back.
Another concern may be the converter and whether or not it matches the neutral or external balance of the 440 you plan on using.
Re: 727 trans question [Re: 5carguy] #1694836
11/05/14 09:58 PM
11/05/14 09:58 PM
scratchnfotraction Offline
Thanks in advance
383/400/cast crank 440 share the same weighted TC.
the BB 727 case fits B/RB engines.
its the correct balance on the TC that makes it all come together.
I used a 77 B/400 weighted TC and 727 trans on my 78 cast crank 440 engine.
