Driveshaft length for 72 Duster 8 3/4 and 4 speed od #169466
12/17/08 06:19 PM
12/17/08 06:19 PM
Hazlet, NJ
440Satellite Offline OP
super gas
super gas
Hazlet, NJ
Hey, maybe someone can help me out. I have a 72 Duster with a 318 a 4 speed overdrive manual tranny and an 8 1/4 rear. I'm going to be swaping out to an 8 3/4 rear so I'm going to need a new driveshaft.
Does anyone know the proper length driveshaft from center of u-joint to center of u-joint, for a 4 speed a-body and 8 3/4? I want to try to find a used driveshaft so its ready to go when I swap rears instead of putting in the rear then having the one I have shortened. Thanks
Butch
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Re: Driveshaft length for 72 Duster 8 3/4 and 4 speed o [Re: 440Satellite] #169467
12/17/08 06:53 PM
12/17/08 06:53 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
48.99 is the standard length shaft for a 4 speed 8.75 set up.
The 8.25 rear uses a DS about 1" longer. You won't be able to use it with the 8.75 rear.
A list of DS lengths.
http://www.autohobbydigest.com/tables.php?17_driveshafts_slip_yoke
Re: Driveshaft length for 72 Duster 8 3/4 and 4 speed o [Re: RobX4406] #169468
12/17/08 08:27 PM
12/17/08 08:27 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Thanks alot, just the info I needed your the man!!!!!
Butch
