Fast Ratio pit and idler arms #1694423
11/04/14 04:59 PM
11/04/14 04:59 PM
So-Cal
I
IB-CUDA Offline OP
IB-CUDA  Offline OP
I
So-Cal
Hi Guy's,
I have the Firm Feel fast ratio arms.
I want to run some Doug headers with my 70 cuda (383 auto)
Does anyone know if they will clear?
Re: Fast Ratio pit and idler arms [Re: IB-CUDA] #1694424
11/04/14 05:08 PM
11/04/14 05:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I thought the Firm Feel website has a list of headers that will fit?
Re: Fast Ratio pit and idler arms [Re: autoxcuda] #1694425
11/04/14 05:28 PM
11/04/14 05:28 PM
So-Cal
I
IB-CUDA Offline OP
IB-CUDA  Offline OP
I
So-Cal
They Do and dougs isn't listed. I called Dick at F.F and he suggested I post.
Thx
Re: Fast Ratio pit and idler arms [Re: IB-CUDA] #1694426
11/04/14 07:29 PM
11/04/14 07:29 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
MY FF idler arm barely misses the pasenger side exhaust. I'm running a TT stock exhaust. I have to take the grease zerk off to keep it from hitting. 71 RR/ 452 big block
Re: Fast Ratio pit and idler arms [Re: dart4forte] #1694427
11/05/14 04:11 AM
11/05/14 04:11 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
i thought I remember reading somewhere that the dougs do hit, hopefully someone can chime in who owns them
Re: Fast Ratio pit and idler arms [Re: dangina] #1694428
11/05/14 05:16 AM
11/05/14 05:16 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Not sure if it helps, but in my 70 Charger, I run the 2" TTI headers on my 440/493. The TTI instructions state that the FR arms will NOT clear, yet they do by 3/8" or more.
Re: Fast Ratio pit and idler arms [Re: Kern Dog] #1694429
11/05/14 05:08 PM
11/05/14 05:08 PM
So-Cal
I
IB-CUDA Offline OP
IB-CUDA  Offline OP
I
So-Cal
Bump..
Sure hoping somebody out has tried Dougs on a Big block E-body
Re: Fast Ratio pit and idler arms [Re: IB-CUDA] #1694430
11/09/14 09:42 PM
11/09/14 09:42 PM
Los Angeles, CA
JF_Moparts Offline
JF_Moparts  Offline
Los Angeles, CA
This might be helpful or not, but I have the fast ratio arms on my 71 Satellite 340 and I run the Hedman block hugger headers. They output in front of the centerlink so you then have to route the exhaust over the steering linkage and out. It's a little bit of a pain but it's worked for me for the past 8 years.
Link to the big block version:
http://www.summitracing.com/parts/hed-78076/applications/make/plymouth?prefilter=1
Edit: Looking at the picture of the big block headers, they curve a bit to the back, unlike the small block ones. It still looks like it would clear, but I don't know for sure.
Re: Fast Ratio pit and idler arms [Re: IB-CUDA] #1694431
11/10/14 06:21 PM
11/10/14 06:21 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Bump..
I have had a few different headers(1 3/4 & 2") on my Challenger 440/505 and they all cleared. Seems that most 1 3/4 headers are designed with similar tube routing. Currently I have 2" TTI's and I have tons of room.
A buddy of mine has 1 7/8 TTI's in a BB cuda and no way those would clear.
I am assuming you are looking at 1 3/4" headers?
Re: Fast Ratio pit and idler arms [Re: IB-CUDA] #1694432
11/11/14 03:17 PM
11/11/14 03:17 PM
Iowa
jon01 Offline
jon01  Offline
Iowa
Bump..
I scoured for the same info for B-bodies with Doug's 2" primaries.
Dick said he'd ship me a set, if they fit cool, if not, don't beat them up trying them on and he'd take them back. Maybe ask him if he'd do the same for you?
Re: Fast Ratio pit and idler arms [Re: jon01] #1694433
11/11/14 04:05 PM
11/11/14 04:05 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Bump..
Did Dougs with 2" primary and B-body work for you?
What year B-body?
What motor? Raised block (440,413, etc) OR low deck (383, 400, etc)?
How much clearance at Idler and Pitman.
An E-body should be extremely close to same clearance there. The K-members are interchangeable for function.
Re: Fast Ratio pit and idler arms [Re: RTSE4ME] #1694434
11/11/14 05:34 PM
11/11/14 05:34 PM
So-Cal
I
IB-CUDA Offline OP
IB-CUDA  Offline OP
I
So-Cal
RTSE,
when you tried the 1-3/4 headers you had F.F fast ratio arms on?
If so could you tell me which one's worked for you, and these were above the steering link type correct?
FYI I spoke to a tech guy at Pertronix (dougs) and he said no-way they would fit. that they barely fit a normal pitman /idler arm.
But you know how it is with tech guys on the phone.....
Re: Fast Ratio pit and idler arms [Re: IB-CUDA] #1694435
11/12/14 01:31 PM
11/12/14 01:31 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
Yes, the fast ratio arms were installed. Both sets were above the linkage. One set were hedmans. The other set I have no idea. They were an old set I used for engine break in. The tube routing was identical only difference that I could tell was flange thickness. I would bet doug's would fit but it is not my money.
Firm Feel lists on their website that 2" tti's don't fit but they have more clearance than any header I have seen.
Re: Fast Ratio pit and idler arms [Re: RTSE4ME] #1694436
11/13/14 03:43 AM
11/13/14 03:43 AM
So-Cal
I
IB-CUDA Offline OP
IB-CUDA  Offline OP
I
So-Cal
Thx RTSE for the info. Definently gives me a better feeling on which way to go here.
Re: Fast Ratio pit and idler arms [Re: autoxcuda] #1694437
11/24/14 02:30 PM
11/24/14 02:30 PM
Iowa
jon01 Offline
jon01  Offline
Iowa
Bump..
What year B-body?
Sorry, just saw this.
I decided to go with a FR box and stick with the stock arms.
68 Charger R/T - #'s matching car, 499/727/3.91
