Re: Fast Ratio pit and idler arms
[Re: IB-CUDA]
#1694430
11/09/14 09:42 PM
11/09/14 09:42 PM
Posts: 1,161 Los Angeles, CA
JF_Moparts
Los Angeles, CA
This might be helpful or not, but I have the fast ratio arms on my 71 Satellite 340 and I run the Hedman block hugger headers. They output in front of the centerlink so you then have to route the exhaust over the steering linkage and out. It's a little bit of a pain but it's worked for me for the past 8 years. Link to the big block version: http://www.summitracing.com/parts/hed-78076/applications/make/plymouth?prefilter=1Edit: Looking at the picture of the big block headers, they curve a bit to the back, unlike the small block ones. It still looks like it would clear, but I don't know for sure.
[Re: IB-CUDA]
#1694431
11/10/14 06:21 PM
11/10/14 06:21 PM
Posts: 2,042 MD
RTSE4ME
MD
Bump.. Sure hoping somebody out has tried Dougs on a Big block E-body
I have had a few different headers(1 3/4 & 2") on my Challenger 440/505 and they all cleared. Seems that most 1 3/4 headers are designed with similar tube routing. Currently I have 2" TTI's and I have tons of room. A buddy of mine has 1 7/8 TTI's in a BB cuda and no way those would clear. I am assuming you are looking at 1 3/4" headers?
[Re: IB-CUDA]
#1694432
11/11/14 03:17 PM
11/11/14 03:17 PM
Posts: 661 Iowa
jon01
Iowa
I scoured for the same info for B-bodies with Doug's 2" primaries. Dick said he'd ship me a set, if they fit cool, if not, don't beat them up trying them on and he'd take them back. Maybe ask him if he'd do the same for you?
[Re: jon01]
#1694433
11/11/14 04:05 PM
11/11/14 04:05 PM
Posts: 27,466 So Cal
autoxcuda
So Cal
Did Dougs with 2" primary and B-body work for you?
What year B-body?
What motor? Raised block (440,413, etc) OR low deck (383, 400, etc)?
How much clearance at Idler and Pitman.
An E-body should be extremely close to same clearance there. The K-members are interchangeable for function.
[Re: RTSE4ME]
#1694434
11/11/14 05:34 PM
11/11/14 05:34 PM
Posts: 34 So-Cal
IB-CUDA
So-Cal
RTSE, when you tried the 1-3/4 headers you had F.F fast ratio arms on? If so could you tell me which one's worked for you, and these were above the steering link type correct? FYI I spoke to a tech guy at Pertronix (dougs) and he said no-way they would fit. that they barely fit a normal pitman /idler arm. But you know how it is with tech guys on the phone.....
