Valve cover gaskets #1693210
11/01/14 02:03 PM
11/01/14 02:03 PM
Europe
rory73 Offline OP
rory73  Offline OP
Europe
Hi, quick question:
I'll remove the valve covers on my 440 to check TDC and replace the cork gaskets after doing so. Found an unused FelPro set in the garage but I'm not sure if the belong to the 440 or the 318 in my other car. No parts number whatsoever. Any way of finding out if they're the correct ones?
Tim
Re: Valve cover gaskets [Re: rory73] #1693211
11/01/14 02:46 PM
11/01/14 02:46 PM
md
mopars4ever Offline
mopars4ever  Offline
md
post a picture and we will ID it. btw small block and big block gaskets aren`t even close.
Re: Valve cover gaskets [Re: rory73] #1693212
11/01/14 02:46 PM
11/01/14 02:46 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
6 bolt holes total, 4 on bottom row and 2 on top of gasket should be 440.
Re: Valve cover gaskets [Re: buildanother] #1693213
11/01/14 03:06 PM
11/01/14 03:06 PM
Europe
rory73 Offline OP
rory73  Offline OP
Europe
ok sounds like SB then, dang!
Re: Valve cover gaskets [Re: mopars4ever] #1693214
11/01/14 04:04 PM
11/01/14 04:04 PM
Europe
rory73 Offline OP
rory73  Offline OP
Europe
Uhm, having placed yet another order with Summit I see what you mean!
