2009 5.9 magmun #1692946
10/31/14 10:15 PM
10/31/14 10:15 PM
granite bay ca
dodgeguy7714 Offline OP
granite bay ca
When was the last year of a 5.9 magnum gas motor in a Durango RT? looking at the caster member has me confused it is 20090 on right hand side of block, 360 stamped on the other side left.
Re: 2009 5.9 magmun [Re: dodgeguy7714] #1692947
10/31/14 10:36 PM
10/31/14 10:36 PM
granite bay ca
granite bay ca
so am I correct this a 2009 was all I was trying to find out guys
Re: 2009 5.9 magmun [Re: dodgeguy7714] #1692948
10/31/14 10:36 PM
10/31/14 10:36 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'd expect around 2003, when the 5.7 Hemi came out.
edit, per wikipedia
The 5.9L Magnum was available until the 2003 model year, when it was replaced with the 5.7L Hemi V8 engine.
Re: 2009 5.9 magmun [Re: GoodysGotaCuda] #1692949
11/01/14 12:06 AM
11/01/14 12:06 AM
Andrewh Offline
Andrewh  Offline
I have heard 2003, but I have not seen one newer than 2001.
Re: 2009 5.9 magmun [Re: Andrewh] #1692950
11/01/14 01:07 AM
11/01/14 01:07 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I'm pretty sure the gas 5.9 mag was still the standard engine in 2002 Ram 3/4 & 1 ton pickups...
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 2009 5.9 magmun [Re: GO_Fish] #1692951
11/01/14 01:18 AM
11/01/14 01:18 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 2500 and 3500 got the 5.7 HEMI in 2002, a year before it was offered in the 1500 model.
Re: 2009 5.9 magmun [Re: GO_Fish] #1692952
11/01/14 01:23 AM
11/01/14 01:23 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Yep they were done in 03. Late 02 and 03 blocks had 5 bolt motor mount bosses instead of the earlier 3 bolt style so they could be fitted in the new DR body style rams. Hemis came out first in 03 in the DR 3/4 and 1 tons. No hemis ever in BR/BE bodies.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2009 5.9 magmun [Re: dodgeguy7714] #1692953
11/02/14 03:56 PM
11/02/14 03:56 PM
Hershey, PA
73MagDuster Offline
73MagDuster  Offline
Hershey, PA
2003 was the last year for the 5.9L in the Durango. It could still be had in the Dakota for 2004.
As stated the HEMI was introduced in the 2003 HD DR, and was a late availability option on the 2003 1500 DR.
Re: 2009 5.9 magmun [Re: 73MagDuster] #1692954
11/03/14 02:01 PM
11/03/14 02:01 PM
dogdays Offline
dogdays  Offline
You are mistaking another casting number for the casting date number.
The casting date number is really hard to mistake for anything else. Once you see it you'll know.
Here's a quote from Hot Rod Magazine:
"Month/Day/Year: This method is used on most cast-iron parts, such as cylinder blocks, cylinder heads, and intake and exhaust manifolds. Example: 8 19 69 = August 19, 1969.
Read more: http://www.hotrod.com/how-to/engine/mopp-0110-taking-inventory-date-coding/#ixzz3I1N2aDzD"
R.
Re: 2009 5.9 magmun [Re: Kern Dog] #1692955
11/03/14 03:33 PM
11/03/14 03:33 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
You sure on that?? 2002 3/4 & 1 tons still used the Ram gen II body style. So you're saying they put Gen III hemi in the Gen II ram. I don't think they did that.
Re: 2009 5.9 magmun [Re: GO_Fish] #1692956
11/03/14 03:53 PM
11/03/14 03:53 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
02 is old body style in the 2500-3500 and never came with a hemi, that came in 03 with the new ugly body.
They used 5.9s for most of 03 in the 1500 I have personally seen both but mostly 5.9s.
The durango last year was 03 for the 5.9(I just sold an 02 R/T) then they changed to the butt ugly body for 04 with 4.7 and 5.7s.
The dakota did not get a 5.9 in 04 even though they had R/Ts (they used a 4.7 and some stickers).
In any case the last 5.9 was used in an 03
