496 with Stealth CNC heads #1691937
10/29/14 04:50 PM
10/29/14 04:50 PM
Harleysville, PA USA
Tommy D Offline OP
Tommy D  Offline OP
Is anyone on here running a 440 Source, 440 based stroker combo with the 440 Source CNC Stealth Heads? I'm curious of your performance and cam choices. Also, what is the final compression ratio of your engine. Tommy
Re: 496 with Stealth CNC heads [Re: Tommy D] #1691938
10/29/14 07:04 PM
10/29/14 07:04 PM
wyo
70 vcodecuda Offline
wyo
just got it running used 440 source 4.25 kit with 2.20 rods
zero deck .040 gaskets came in at 10.3 used a bullit hyd roller
236& 242 at .050 with a six pack cnc'd stealth's
only a couple hundred miles but it is a beast great idle
pulls hard form 2500 to 6000+
ton's of power and looks bone stock
1970 Cuda V code 4speed Shaker 2009 Challenger RT 2003 Ram 2500 Quad Cab CTD
Re: 496 with Stealth CNC heads [Re: 70 vcodecuda] #1691939
10/29/14 07:18 PM
10/29/14 07:18 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
Im getting ready to build a pump gas 505 for my 63 with CNC super stealth with Maxwedge intake opening
Re: 496 with Stealth CNC heads [Re: Bishop] #1691940
10/30/14 12:50 PM
10/30/14 12:50 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Hi Tom as I have not seen you here in a bit. Tom I use the 440Source 4.15 stroker kit with dished pistons as I use the basic EZ heads and with the D-dish pistons I have 10.6 comp for pump friendly 92. I do have .045 quench also and a custom solid flat tappet to keep the cyl pressure down enough for pump gas. I drive it on the street 99% of the time and I use the Indy dual plane with an 850 DP as the driveabilty is very good. I am sure the Stealth heads would work about as good with porting as my EZ's are just cleaned up and not seriously ported. Ron
Re: 496 with Stealth CNC heads [Re: 383man] #1691941
10/30/14 01:44 PM
10/30/14 01:44 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Last spring I did one. B based 496, but not Source parts. Customer supplied a kit from Muscle Motors. Heads were CNC Stealths with std wedge openings. Cam was a small custom solid flat tappet from Porter Racing Heads. With factory exh manifolds, full stock exhaust, dual plane, and Holley it makes on the order 430hp, 440tq to the tires. Have to check my notes but I think it came out to 10.4:1 static with dished pistons.
Re: 496 with Stealth CNC heads [Re: moper] #1691942
10/30/14 03:59 PM
10/30/14 03:59 PM
Tommy D Offline OP
Tommy D  Offline OP
Thank you for the responses. I love the two '63 Plymouths in this post. Beautiful cars. Guess I'm prejudiced. I'm having a 498" Source kit put together with the CNC heads. I'm trying to get an idea what to expect from it's performance. I'm going to run a Comp Cams .575" lift "Street Solid Roller". 3700 pound '69 Road Runner with 4.30 gears and a 3800 RPM converter.
Ron, we've had troubles with the race car ("FRUSTRATION" is it's name). In the down time, I found surfing with my son is a pretty good alternative. I still love vintage drag cars, but it's tough to compare the track to the beach! I hope to see you soon. Tell Gary I said hello. Tommy
Re: 496 with Stealth CNC heads [Re: Tommy D] #1691943
10/30/14 10:52 PM
10/30/14 10:52 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
The beach???
Re: 496 with Stealth CNC heads [Re: scatpacktom] #1691944
10/31/14 08:57 AM
10/31/14 08:57 AM
Tommy D Offline OP
Tommy D  Offline OP
You'd better believe it!
