Ralley Tach Wiring #1691427
10/27/14 09:58 PM
10/27/14 09:58 PM
okla.
O
okie Offline OP
okie  Offline OP
O
okla.
I got one of the OEM ralley tach's in my 70 RR. It just has one wire running up to the coil. Which side of the coil do I hook it up on? I guess old age is setting in and I can't remember which one I took it off of when I pulled the motor. I should be able to start it Tues. so I need to get this hooked up. Thanks
Re: Ralley Tach Wiring [Re: okie] #1691428
10/27/14 09:59 PM
10/27/14 09:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Negative.
