Page 2 of 3 1 2 3
Re: 2ram quad cab 1500 water sound in dash [Re: kenworth_goose] #1690997
11/01/14 10:31 AM
11/01/14 10:31 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Well, changed my t-stat today. Used my vacuum tool to pump down the coolant system. Guess what? Sloshing in the dash is GONE!
I would still love for you to explain how that has anything to do with water sloshing in the dash? only water running through the dash is in the heater core. unless it's leaking into the heater box there is no way it can slosh. your intake or thermostat has absolutely nothing to do with it. if you have not run it in a while the leaking water could have evaporated or leaked out. sometimes on your carpet.
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1690998
11/01/14 11:49 AM
11/01/14 11:49 AM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
the sloshing noise will come from having air trapped in the heater core.i think that fancy filler pushes air out
Re: 2ram quad cab 1500 water sound in dash [Re: d-150] #1690999
11/01/14 11:52 AM
11/01/14 11:52 AM
Q
Quicktree Offline
Quicktree  Offline
Q
never happen, and the reason I say that is there is not enough volume of water in a heater core to make a sloshing sound. take a look at an heater core and you should understand.
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1691000
11/02/14 06:28 AM
11/02/14 06:28 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
so, he's lying then? give it a rest. he fixed it, and described the fix.
Re: 2ram quad cab 1500 water sound in dash [Re: Golden-Arm] #1691001
11/02/14 08:53 AM
11/02/14 08:53 AM
Q
Quicktree Offline
Quicktree  Offline
Q
no he just doesn't understand how it works, he may have fixed his but others with a leaky heater core will be wasting their time messing with that..
Re: 2ram quad cab 1500 water sound in dash [Re: kenworth_goose] #1691002
11/02/14 09:57 AM
11/02/14 09:57 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
On my 1995 Ram Magnum 5.9 V8
I have heard
"running water noises"
from the passenger side of the dash
each time i have changed coolant.
It has happened with
50/50 antifreeze mix
straight water
and Evans NPG coolant, which is about as viscous as maple syrup.
I have been able to get rid of the water running like noise by parking the truck on a steep uphill and running the fully warmed up engine at 1500 RPM for ten to twenty minutes.
It is interesting to know that a vacuum filling technique helps on coolant. Vacuum filling certainly seems to help on brake fluid fills.
I know I presently have a slow coolant weep on the upper driver side corner of the timing cover gasket.
I suspect this is one source of air getting in the coolant system.
Small coolant leaks at the timing cover gasket corners seems to be common on older Magnum V8s.
Re: 2ram quad cab 1500 water sound in dash [Re: 360view] #1691003
11/02/14 11:07 AM
11/02/14 11:07 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I think we are talking about 2 different sounds/noise. running water vs sloshing. the leaking heater core sounds like a box full of water and usually happens when the vehicle is moving or turning which equals slosh. a running water sound could happen with the vehicle setting still and motor running.
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1691004
11/02/14 11:11 AM
11/02/14 11:11 AM
Q
Quicktree Offline
Quicktree  Offline
Q
you will also get a nasty smell when the heater core has leaked for a while
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1691005
11/02/14 11:49 AM
11/02/14 11:49 AM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
When the air is trapped at the highest point, which is the core, you get this noise. Universal problem across all manufacturers, which is why the tool was made.
If you have a core leak you also have similar noise from water moving around in the box and from the air introduced into the core from the leak.
Use the tool and you will quickly see you have a system leak. When you go to pull vacuum you will see the vacuum won't hold.
Up to you to figure out where the leak is.
Re: 2ram quad cab 1500 water sound in dash [Re: njmopar] #1691006
11/02/14 02:33 PM
11/02/14 02:33 PM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1691007
11/03/14 01:56 PM
11/03/14 01:56 PM
ky.
K
kenworth_goose Offline
K
ky.
Some of these know it all just really piss me off! I'm 47 years old, been working on cars since I could hold a wrench! ASE certified Master Tech! I wish people would get some real world experience and stop acting like they know everything when they don't know jack! Thanks to the people that do understand the newer vehicles and what knowledge they require. I'm just about done with this site and all the negativity!!!!!!!!
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1691008
11/04/14 12:18 AM
11/04/14 12:18 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
slow-twig.... it does sound like "sloshing". I've seen it, lived it more than a few times on the older BR/BE Dodge rams. Start them up cold in the morning and it will sound like a garden hose running.....I chit you knot!
Re: 2ram quad cab 1500 water sound in dash [Re: kenworth_goose] #1691009
11/04/14 08:12 AM
11/04/14 08:12 AM
Q
Quicktree Offline
Quicktree  Offline
Q
only 47? I was working on cars when you were still in high school. did you miss the post where I described two different issues? saying your solution to your problem would correct a bad heater core is wrong, but you are ASE certified you should know that. and i'll bet I had ASE certification before you ever thought of it? don't be so dam thin skinned
Re: 2ram quad cab 1500 water sound in dash [Re: J_BODY] #1691010
11/04/14 08:13 AM
11/04/14 08:13 AM
Q
Quicktree Offline
Quicktree  Offline
Q
Jboy thats not a heater core problem..
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1691011
11/04/14 02:01 PM
11/04/14 02:01 PM
st.cloud fl
st.cloud fl
I.am not an.ase mechanic but i play one on the weekend
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1691012
11/05/14 01:31 AM
11/05/14 01:31 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Well it's not water running into the evaporator!! Like I mentioned way back..... bad radiator cap, air leak at the hose from the overflow can contribute to this airpocket which will lead to this issue.
Re: 2ram quad cab 1500 water sound in dash [Re: J_BODY] #1691013
11/05/14 04:27 AM
11/05/14 04:27 AM
Q
Quicktree Offline
Quicktree  Offline
Q
it will lead to one of the possible issues. not the only cause
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1691014
11/05/14 12:02 PM
11/05/14 12:02 PM
ky.
K
K
ky.
Re: 2ram quad cab 1500 water sound in dash [Re: kenworth_goose] #1691015
11/05/14 02:22 PM
11/05/14 02:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
grow up, and don't be so dam sensitive. you are not the only person on the planet with a little knowledge. there will always be a different view which is a good thing.
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1691016
11/05/14 05:09 PM
11/05/14 05:09 PM
ky.
K
K
ky.
Page 2 of 3 1 2 3
