Re: 2ram quad cab 1500 water sound in dash
[Re: earthmover]
#1690978
10/26/14 11:15 PM
10/26/14 11:15 PM
Posts: 516 ND
dodgedon
ND
Are you sure its not the water "IN" the heater core? My dads truck does this. Like it has a little air in the system when you first start it.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: earthmover]
#1690987
10/29/14 03:34 AM
10/29/14 03:34 AM
Quicktree
omg I hope that's not the problem the heater core....
the whole dash will have to come out
[Re: Quicktree]
#1690988
10/29/14 06:27 PM
10/29/14 06:27 PM
Posts: 2,046 ky.
kenworth_goose
ky.
heater core is leaking or ac drain stopped up
Neither is the problem! I have the same issue since doing my intake pan, It only has air in it. My truck didn't do it until I done the intake. Now it does. I need to get the air out as well. And I haven't lost a drop of coolant so I know it's not leaking.
[Re: kenworth_goose]
#1690989
10/29/14 07:40 PM
10/29/14 07:40 PM
Quicktree
well i just had my heater core replaced because it was leaking and doing the same exact thing...
[Re: Quicktree]
#1690990
10/29/14 08:15 PM
10/29/14 08:15 PM
Posts: 2,046 ky.
kenworth_goose
ky.
Well mine isn't leaking and it makes the same sound. Didn't make that sound until I fixed the intake gasket,
#1690991
10/29/14 08:46 PM
10/29/14 08:46 PM
Quicktree
explain how you can get water sloshing under your dash from an intake gasket? and mine is a diesel. there is nothing in there but the heater core and A/C evaporator.
[Re: earthmover]
#1690993
10/30/14 02:39 PM
10/30/14 02:39 PM
Posts: 1,331 Clinton, NJ
njmopar
Clinton, NJ
Owned my truck from day 1 and it never made this sloshing noise until I changed the coolant. Despite attempts at bleeding out the air, could never fully resolve. Then I got a vacuum filler for coolant and now, no more noise. Got this tool http://www.uview.com/index.cfm?DSP=Produ...ng&id=45700Very slick and makes refill very easy. A must on most modern engines that have miles of coolant passages or Benz products with 2 heater cores, where air can get trapped.
#1690996
11/01/14 02:31 AM
11/01/14 02:31 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Thanks for the follow up, my truck does the same. I will just turn up the radio...
