Page 1 of 3 1 2 3
2ram quad cab 1500 water sound in dash update #1690977
10/26/14 09:55 PM
10/26/14 09:55 PM
nc
E
earthmover Offline OP
E
nc
2002 dodge ram when I drive move the truck sounds like water running in the dash on the passenger side of the truck..i took a blower and blow air in the ac hole that drips the water out I thought it may be blocked ..but I got nothing out of it and the water is still in the dash area somewhere..anybody have any ideas where and how to get it out it drives me crazy everytime the truck moves you hear it running around in the dash ..
Re: 2ram quad cab 1500 water sound in dash [Re: earthmover] #1690978
10/26/14 11:15 PM
10/26/14 11:15 PM
ND
dodgedon Offline
dodgedon  Offline
ND
Are you sure its not the water "IN" the heater core? My dads truck does this. Like it has a little air in the system when you first start it.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 2ram quad cab 1500 water sound in dash [Re: earthmover] #1690979
10/27/14 12:02 AM
10/27/14 12:02 AM
State, country, etc.
gss Offline
gss  Offline
Fill your radiator
Re: 2ram quad cab 1500 water sound in dash [Re: gss] #1690980
10/27/14 01:36 AM
10/27/14 01:36 AM
nc
E
E
nc
radiator is full I thought that myself...sounds like it runs from about middle way of the truck to the door on passenger side..heat works great...ac went out about 3 weeks ago some how..driving down the road and just stop cooling put Freon in it and still nothing compressor sounds like its knocking ..but I don't think that has anything to do with the water sound as its been doing it a little longer then the ac going out...
Re: 2ram quad cab 1500 water sound in dash [Re: earthmover] #1690981
10/27/14 02:05 AM
10/27/14 02:05 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
If you aren't getting water leaking on the floor, just hearing it slosh, check the cowl drains.
It takes gasoline to interest me.
Re: 2ram quad cab 1500 water sound in dash [Re: earthmover] #1690982
10/27/14 11:10 AM
10/27/14 11:10 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
My 2001 had the same thing, it was a bad heater core that leaked into the HVAC system and sloshed around. You only have to take the entire dash out to replace the heater core, DAMHIK!
JB Rhinehart, Realist
A-Body's RULE!
Re: 2ram quad cab 1500 water sound in dash [Re: Rhinodart] #1690983
10/27/14 07:10 PM
10/27/14 07:10 PM
nc
E
E
nc
omg I hope that's not the problem the heater core....
Re: 2ram quad cab 1500 water sound in dash [Re: earthmover] #1690984
10/28/14 01:06 AM
10/28/14 01:06 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No water ever leaked anywhere, but I heard the sloshing for over a year, then the heat would not work that winter. The A/C was still functioning though.
A-Body's RULE!
Re: 2ram quad cab 1500 water sound in dash [Re: earthmover] #1690985
10/28/14 11:06 PM
10/28/14 11:06 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
test your radiator cap..... seen this a ton over the years. If it tests bad, replace it. It will take some time to work the air out. Luckily we have a driveway about a block from work that has to be at least a 10% grade. We'll run them at 2500 rpm with the nose in the air for 5 minutes or so. Works the air out pretty quick. Also make sure the overflow hose is secure at the nipple on the radiator. Old age made them start leaking air into the system from a loose fitting hose.
Re: 2ram quad cab 1500 water sound in dash [Re: J_BODY] #1690986
10/29/14 03:33 AM
10/29/14 03:33 AM
Q
Quicktree Offline
Quicktree  Offline
Q
heater core is leaking or ac drain stopped up
Re: 2ram quad cab 1500 water sound in dash [Re: earthmover] #1690987
10/29/14 03:34 AM
10/29/14 03:34 AM
Q
Quicktree Offline
Quicktree  Offline
Q
the whole dash will have to come out
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1690988
10/29/14 06:27 PM
10/29/14 06:27 PM
ky.
K
kenworth_goose Offline
K
ky.
Neither is the problem! I have the same issue since doing my intake pan, It only has air in it. My truck didn't do it until I done the intake. Now it does. I need to get the air out as well. And I haven't lost a drop of coolant so I know it's not leaking.
Re: 2ram quad cab 1500 water sound in dash [Re: kenworth_goose] #1690989
10/29/14 07:40 PM
10/29/14 07:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
well i just had my heater core replaced because it was leaking and doing the same exact thing...
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1690990
10/29/14 08:15 PM
10/29/14 08:15 PM
ky.
K
K
ky.
Well mine isn't leaking and it makes the same sound. Didn't make that sound until I fixed the intake gasket,
Re: 2ram quad cab 1500 water sound in dash [Re: kenworth_goose] #1690991
10/29/14 08:46 PM
10/29/14 08:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
explain how you can get water sloshing under your dash from an intake gasket? and mine is a diesel. there is nothing in there but the heater core and A/C evaporator.
Re: 2ram quad cab 1500 water sound in dash [Re: Quicktree] #1690992
10/30/14 01:32 PM
10/30/14 01:32 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Mike where the heck is that duster
Re: 2ram quad cab 1500 water sound in dash [Re: earthmover] #1690993
10/30/14 02:39 PM
10/30/14 02:39 PM
Clinton, NJ
N
njmopar Offline
njmopar  Offline
N
Clinton, NJ
Owned my truck from day 1 and it never made this sloshing noise until I changed the coolant. Despite attempts at bleeding out the air, could never fully resolve.
Then I got a vacuum filler for coolant and now, no more noise.
Got this tool http://www.uview.com/index.cfm?DSP=Produ...ng&id=45700
Very slick and makes refill very easy. A must on most modern engines that have miles of coolant passages or Benz products with 2 heater cores, where air can get trapped.
Re: 2ram quad cab 1500 water sound in dash [Re: njmopar] #1690994
10/30/14 06:52 PM
10/30/14 06:52 PM
ky.
K
K
ky.
I have something similar to that but mine locks on like a radiator cap. I didn't use mine when I done my intake, but I have to change my thermostat now so I will to make sure all the air is out.
Re: 2ram quad cab 1500 water sound in dash [Re: kenworth_goose] #1690995
10/31/14 07:15 PM
10/31/14 07:15 PM
ky.
K
K
ky.
Well, changed my t-stat today. Used my vacuum tool to pump down the coolant system. Guess what? Sloshing in the dash is GONE!
Re: 2ram quad cab 1500 water sound in dash [Re: kenworth_goose] #1690996
11/01/14 02:31 AM
11/01/14 02:31 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Thanks for the follow up, my truck does the same.
I will just turn up the radio...
Page 1 of 3 1 2 3
