360 wont rev past 3k.... HELP #1690257
10/25/14 01:10 AM
10/25/14 01:10 AM
mn
moparguy93 Offline OP
mn
I recently built a 360 small block. I took it out for a test drive to day and I noticed once I hit 3000 rpm it stumble and starts popping bad. it happens in all gears. when its in park it only revs to 3500 but will stumble. my rev limitor is set at 6200. please help.. THANKS
engine specs-
74 360 bored .030 over
kb 107 pistons
eagle rods and cast crank
lunati 513/533 cam
1.6 roller rockers
lunati valvetrain
m1 intake 750 speed demon carb
6.5 fuel pressure
jets 74/83
6.5 power valve 9 hg idle/ 6 in gear
msd 6al-2 ignition/pro billet distributor
Re: 360 wont rev past 3k.... HELP [Re: moparguy93] #1690258
10/25/14 02:05 AM
10/25/14 02:05 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
What ignition box are you using?
Hutch
Re: 360 wont rev past 3k.... HELP [Re: Hutch] #1690259
10/25/14 02:08 AM
10/25/14 02:08 AM
mn
mn
msd 6al 2 programmable part number 6530
Re: 360 wont rev past 3k.... HELP [Re: moparguy93] #1690260
10/25/14 02:20 AM
10/25/14 02:20 AM
Ontario Canada
Hutch Offline
Hutch  Offline
Ontario Canada
Sorry, thought maybe you had a 7 series programmable box that may have had a downtrack rev limiter (time based). They can do that.
Hutch
Re: 360 wont rev past 3k.... HELP [Re: moparguy93] #1690261
10/25/14 04:10 AM
10/25/14 04:10 AM
Q
Quicktree Offline
Quicktree  Offline
Q
check your float levels, if thats ok find another control box
Re: 360 wont rev past 3k.... HELP [Re: Quicktree] #1690262
10/25/14 05:55 AM
10/25/14 05:55 AM
mn
mn
Just checked my float level and they are both high... will that cause the problem I'm having
Re: 360 wont rev past 3k.... HELP [Re: moparguy93] #1690263
10/25/14 07:57 AM
10/25/14 07:57 AM
Q
Quicktree Offline
Quicktree  Offline
Q
it's possible if it running over.lower them to about half way in the sight glass and try it
Re: 360 wont rev past 3k.... HELP [Re: Quicktree] #1690264
10/25/14 08:03 AM
10/25/14 08:03 AM
mn
mn
OK I'll lower than floats in the morning to see if that helps.. any other suggestions from anybody?? Exhaust smells real bad and the plugs look fine..
Re: 360 wont rev past 3k.... HELP [Re: moparguy93] #1690265
10/25/14 08:11 AM
10/25/14 08:11 AM
Arizona
Chris'sBarracuda Offline
Arizona
1. Disconnect the tach.
2. Try a different box.
Chris..
Re: 360 wont rev past 3k.... HELP [Re: Chris'sBarracuda] #1690266
10/25/14 08:50 AM
10/25/14 08:50 AM
Q
Quicktree Offline
Quicktree  Offline
Q
yea it would be great if you could borrow another 6al-2 and swap it out.
Re: 360 wont rev past 3k.... HELP [Re: Quicktree] #1690267
10/25/14 09:52 AM
10/25/14 09:52 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
is this the 1st time driving it.....i had the same problem and the pickup wires going to the distributor were backwards.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: 360 wont rev past 3k.... HELP [Re: instigator] #1690268
10/25/14 11:42 AM
10/25/14 11:42 AM
Pennsylvania
Red 79 Offline
Red 79  Offline
Pennsylvania
First thing I'd check with symptoms you describe. The distributor pick-up will work either way it's hooked up, but if backwards it throws the rotor phasing way off.
Re: 360 wont rev past 3k.... HELP [Re: Red 79] #1690269
10/25/14 08:45 PM
10/25/14 08:45 PM
mn
mn
Problem fixed!!!!!! Distributor wires were switched around. Revs to 6k no problem now. Thanks for all the help
Re: 360 wont rev past 3k.... HELP [Re: instigator] #1690270
10/25/14 09:49 PM
10/25/14 09:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
great job i totally forgot about that.
Re: 360 wont rev past 3k.... HELP [Re: Quicktree] #1690271
10/25/14 10:15 PM
10/25/14 10:15 PM
Arizona
Arizona
Usually when that's the issue, they cough spit and sputter when trying to start..
Chris..
