Hydraulic or gas rear shocks for stock rear susp.? #1690083
10/24/14 06:47 PM
10/24/14 06:47 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
What are better for Drag racing, hydraulic or gas rear shocks, for a stock mopar leaf springs susp.? Thanks.
Re: Hydraulic or gas rear shocks for stock rear susp.? [Re: ragtop] #1690084
10/24/14 10:16 PM
10/24/14 10:16 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
All(automotive) shocks are hydraulic. Gas shocks use a gas charge in addition to the oil (hydraulic). The gas helps suppress the foaming that is created within the shocks during use. Foam puts bubbles in the oil and prevents the shock consistent dampening performance. So that being said I don't believe most Drag only shocks are gas shocks where as roundy round or street shocks would be. Although the drag shock does do a considerable amount of work each pass typical drag surfaces are considerably smoother than most street and oval surfaces (strokes /per minute)
If this is a Drag only application I don't believe you "Need " a gas shock
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Hydraulic or gas rear shocks for stock rear susp.? [Re: W.I.N. Racing] #1690085
10/24/14 10:42 PM
10/24/14 10:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Is it a street/strip car or drag race only car ? I am still very old school as on my 63 street/strip car I use SS springs and the older MP hydraulic longer shocks for SS springs. They work fine for what I do which is mostly street driving and it has pulled a best 60 ft of 1.50 running 10.70's. Not going to set no world records but it works fine for what I do on a tight budget. Ron
