Re: anyone used this distributor?
[Re: skicker]
#1689846
10/24/14 12:24 PM
10/24/14 12:24 PM
RapidRobert
there was a thread awhile back on those "skip white" dists & I dont remember what the concensus was. I agree it is dirt cheap so something has to be cheap in regards to it you'd think as there ain't no free lunches. One option I would mount an HEI module to the bottom of a chrysler dist and someone (eBay?) sells a tailor made alum plate for that but it is pricey (~$30 iirc) & you could easily make one your self & be sure to use heat sink paste between module/plate & Radio Shack sells a mini tube of that HS. I believe your problem is elsewhere
[Re: RapidRobert]
#1689847
10/24/14 12:54 PM
10/24/14 12:54 PM
Posts: 2,863 middle Tennessee
mopower440
middle Tennessee
. I know I am going to do these tests you all listed. But I still do want something that puts out better spark thazn the stock stuff, and I do like the simplicity of the ready to run setups.
[Re: OzHemi]
#1689849
10/24/14 02:00 PM
10/24/14 02:00 PM
Posts: 947 Goodyear Arizona
midnite360
Goodyear Arizona
My hidden secret is amazon..... Me and my buddy have been buying these for all of our mopar small blocks... Never had a problem. The one wire hookup is nice... and dirt cheap I imagine its the same quality as what you have listed... Amazon
[Re: stumpy]
#1689851
10/24/14 03:05 PM
10/24/14 03:05 PM
Posts: 15,487 Florida
scratchnfotraction
I read about it here on moparts but don't recall what I read. look at speedmaster.com for cheap billet pro-comp dist also. billet SB or BB dist cheap 59$-79$ matter of fact, they have the same elect fuel pump that I buy at my local speed shop for 120$ for 40$ free shipping too. I have started buying from speed master for most of my needs even though the speed shop has the EXACT same thing on the shelf. get 3x as many parts/free shipping for same $ with speed masters. pays to shop around sometimes
[Re: John_Kunkel]
#1689855
10/24/14 04:07 PM
10/24/14 04:07 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I am willing to try that I was going to use the Mallory CD Ignition (comparable to the MSD) that I got for the racer, but I used it in the '87 truck when I converted from the LeanBurn that was giving me grief. I had to buy a vacuum advance distributor to make that work, so in the end I had at least $350.00 in a new ignition system and it does work fine, but for $44.50 + shipping with a lifetime warranty (read the ad) why not? I am willing to be on the "bleeding edge"
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: John_Kunkel]
#1689856
10/24/14 06:04 PM
10/24/14 06:04 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
The distributor in the OP is marketed by dozens of vendors, it uses a CPU from an Australian Holden Commodore. I had one go bad and the replacement CPU costs more than the whole distributor.
I have one out of a Holden on the shelf actually.
Again, they were a Bosch unit.
[Re: OzHemi]
#1689857
10/24/14 06:57 PM
10/24/14 06:57 PM
RapidRobert
After reading this I'd say drop one in (take the cover off) and purchase a spare & wrap it up airtight in a plastic bag (with dessicant if possible) & store it in the trunk
[Re: John_Kunkel]
#1689861
10/25/14 04:54 PM
10/25/14 04:54 PM
mopower440
middle Tennessee
The seller, skip white, said i could buy an extra module from him to carry with me as a spare for 5.95! How the heck can it be good if that cheap?
