anyone used this distributor? #1689844
10/23/14 11:42 PM
10/23/14 11:42 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
anyone used this ready to run inexpensive setup?
http://www.ebay.com/itm/DODGE-PLYMOUTH-4...9ad&vxp=mtr
If so, what do you think about it? Just seems to good to be true being as inexpensive as it is. Even the petronix conversion is more money than this..
Re: anyone used this distributor? [Re: mopower440] #1689845
10/24/14 08:31 AM
10/24/14 08:31 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Never used it but the technology has been around for a while. I have a friend (GM guy ) who has modified the original HEI distributor with a Chrysler style of shaft. He runs them in derby cars religiously. Its definitely an advantage over any of the original Chrysler ignitions. Hook up one wire from the switch and done.
...FAFO...
Re: anyone used this distributor? [Re: skicker] #1689846
10/24/14 12:24 PM
10/24/14 12:24 PM
there was a thread awhile back on those "skip white" dists & I dont remember what the concensus was. I agree it is dirt cheap so something has to be cheap in regards to it you'd think as there ain't no free lunches. One option I would mount an HEI module to the bottom of a chrysler dist and someone (eBay?) sells a tailor made alum plate for that but it is pricey (~$30 iirc) & you could easily make one your self & be sure to use heat sink paste between module/plate & Radio Shack sells a mini tube of that HS. I believe your problem is elsewhere
Re: anyone used this distributor? [Re: RapidRobert] #1689847
10/24/14 12:54 PM
10/24/14 12:54 PM
middle Tennessee
middle Tennessee
. I know I am going to do these tests you all listed. But I still do want something that puts out better spark thazn the stock stuff, and I do like the simplicity of the ready to run setups.
Re: anyone used this distributor? [Re: mopower440] #1689848
10/24/14 01:08 PM
10/24/14 01:08 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Just going to be a cheap chinese thing..makes you wonder about replacement parts or what/if quality it has to it?
Looks sort of like a copy of a Bosch distributor they used in Oz in various makes.
What about going with a petronix on a stock distributor?
Re: anyone used this distributor? [Re: OzHemi] #1689849
10/24/14 02:00 PM
10/24/14 02:00 PM
Goodyear Arizona
midnite360 Offline
midnite360  Offline
Goodyear Arizona
My hidden secret is amazon.....
Me and my buddy have been buying these for all of our mopar small blocks... Never had a problem. The one wire hookup is nice... and dirt cheap I imagine its the same quality as what you have listed...
Amazon
Re: anyone used this distributor? [Re: midnite360] #1689850
10/24/14 02:25 PM
10/24/14 02:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I used one on my last 408 stroker and it perked it up over the stock distributer. I ran it for a year and then sold the truck. Buyer is still running it.
Re: anyone used this distributor? [Re: stumpy] #1689851
10/24/14 03:05 PM
10/24/14 03:05 PM
scratchnfotraction Offline
I read about it here on moparts but don't recall what I read.
look at speedmaster.com for cheap billet pro-comp dist also.
billet SB or BB dist cheap 59$-79$
matter of fact, they have the same elect fuel pump that I buy at my local speed shop for 120$ for 40$ free shipping too.
I have started buying from speed master for most of my needs even though the speed shop has the EXACT same thing on the shelf. get 3x as many parts/free shipping for same $ with speed masters.
pays to shop around sometimes
Re: anyone used this distributor? [Re: stumpy] #1689852
10/24/14 03:05 PM
10/24/14 03:05 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
A friend of mine has one on a 440 in his 58 Savoy "Christine " look a like car. Remove the external chrome cover and it runs forever. That piece covers up some electronics that are mounted to an aluminum heat sink plate. Keeping the cover on it make the electronics heat up to the point the motor craps out.
Re: anyone used this distributor? [Re: mopower440] #1689853
10/24/14 03:33 PM
10/24/14 03:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The distributor in the OP is marketed by dozens of vendors, it uses a CPU from an Australian Holden Commodore. I had one go bad and the replacement CPU costs more than the whole distributor.
Re: anyone used this distributor? [Re: John_Kunkel] #1689854
10/24/14 03:50 PM
10/24/14 03:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Looks a lot like the older GM style cpu.
Re: anyone used this distributor? [Re: John_Kunkel] #1689855
10/24/14 04:07 PM
10/24/14 04:07 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I am willing to try that
I was going to use the Mallory CD Ignition (comparable to the MSD) that I got for the racer, but I used it in the '87 truck when I converted from the LeanBurn that was giving me grief. I had to buy a vacuum advance distributor to make that work, so in the end I had at least $350.00 in a new ignition system and it does work fine, but for $44.50 + shipping with a lifetime warranty (read the ad) why not?
I am willing to be on the "bleeding edge"
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: anyone used this distributor? [Re: John_Kunkel] #1689856
10/24/14 06:04 PM
10/24/14 06:04 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I have one out of a Holden on the shelf actually.
Again, they were a Bosch unit.
Re: anyone used this distributor? [Re: OzHemi] #1689857
10/24/14 06:57 PM
10/24/14 06:57 PM
After reading this I'd say drop one in (take the cover off) and purchase a spare & wrap it up airtight in a plastic bag (with dessicant if possible) & store it in the trunk
Re: anyone used this distributor? [Re: RapidRobert] #1689858
10/24/14 10:40 PM
10/24/14 10:40 PM
middle Tennessee
middle Tennessee
Ya thats the only problem is what if it craps out on the road somewhere..I would have to have a second one in the trunk which makes it not so cheap if i have to buy 2..I emailed the seller and asked about the life of the ECU, he just said, 'It has a lifetime warranty"..
wondering if this will indeed have a much better spark than the stock stuff..
actually, there are 4 different ready to run units, 2 require an external coil and 2 do not..
http://www.ebay.com/itm/Mopar-Chrysler-B...p-/171429048950
http://www.ebay.com/itm/Mopar-Chrysler-B...n-/201154319486
http://www.ebay.com/itm/Mopar-Chrysler-B...p-/201154318490
http://www.ebay.com/itm/Mopar-Chrysler-B...p-/201154319309
Now, which one would you go for?
Re: anyone used this distributor? [Re: mopower440] #1689859
10/25/14 01:40 AM
10/25/14 01:40 AM
middle Tennessee
middle Tennessee
I just found something i like best, mainly because i can keep my current mopar electronic distributor which i already have the advance setup on. This is very cool. Should give me the boost in spark i need. check it out, anyone used this setup?
http://www.designed2drive.com/
Re: anyone used this distributor? [Re: mopower440] #1689860
10/25/14 11:53 AM
10/25/14 11:53 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Re: anyone used this distributor? [Re: John_Kunkel] #1689861
10/25/14 04:54 PM
10/25/14 04:54 PM
middle Tennessee
middle Tennessee
The seller, skip white, said i could buy an extra module from him to carry with me as a spare for 5.95!
How the heck can it be good if that cheap?
Re: anyone used this distributor? [Re: mopower440] #1689862
10/25/14 11:22 PM
10/25/14 11:22 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
It looks like they don't have one for the 383, so now I won't be tempted to use it.
68 Roadrunner. 383 4-spd. Beat up.
Re: anyone used this distributor? [Re: Mebsuta] #1689863
10/26/14 10:10 AM
10/26/14 10:10 AM
middle Tennessee
middle Tennessee
How does this work, Magneto style distributor?
http://www.ebay.com/itm/Mopar-Chrysler-B...ef1&vxp=mtr
would it be reliable and all? never heard of this..
