Re: Best Carb. ????
[Re: okie]
#1689597
10/23/14 11:37 AM
10/23/14 11:37 AM
Posts: 12,053 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
There have been several threads on this subject lately. I believe the best out-of-the-box street carbs today are the new Street Demons. If the car will see more street duty, the 625 would be the better choice.
Master, again and still
Re: Best Carb. ????
[Re: okie]
#1689598
10/23/14 11:40 AM
10/23/14 11:40 AM
Posts: 13,359 Marion, South Carolina [><]
an8sec70cuda
I agree that a 750 would be the largest carb for it. The 383's I've messed with did not like big carbs like a 440 does. I had a mild 383 w/ big valve 906s, 9.5:1 compression, MP 484/284 cam...it ran WAYYY better w/ a 750 than it did when I tried my 830 holley DP on it.
Re: Best Carb. ????
[Re: Rob C]
#1689603
10/23/14 07:57 PM
10/23/14 07:57 PM
Posts: 1,222 okla.
okie
okla.
The 800 is a bit large for the engine. 750 would be my max size for it. You did get the tuning kit for the carb right? You also did not give a wholeot of info on the engine. What exact cam? Headers? Etc...
Depending on what your trying to do& have in the engine and the cars set up, converter, rear gear, tire size, etc.... You may even be able to use a smaller 650!
The cam 475/494 Voodoo with Hp manifolds,DP4B intake, 323 gears with a 2800 stall. Motor is 30 over with block decked and the heads shaved on it. Has KB pistons and is suppose to be about 9.3-1 on compression. It is an auto. I did get the tuning kit but I think I will be better off getting another carb. I don't remember the back tires they are big 15" ones that would fit the car. I just have never had good luck out of the edlebrocks. Ronnie
Re: Best Carb. ????
[Re: okie]
#1689605
10/23/14 08:51 PM
10/23/14 08:51 PM
Posts: 1,222 okla.
okie
okla.
The tires are 275-60-15's
