69 R/T drive shaft #1689578
10/23/14 10:22 AM
10/23/14 10:22 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I just bought a 69 R/T, 440 auto with a factory 4.10 Dana. Should the drive shaft have a weight ring on the tranny end or not? I've seen them on earlier cars, but not a 69. It has a SPD of 9-24.
Re: 69 R/T drive shaft [Re: fastmark] #1689579
10/23/14 06:38 PM
10/23/14 06:38 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
Inertia ring used more on 68 build dates .
Re: 69 R/T drive shaft [Re: 1969ronnie] #1689580
10/23/14 06:44 PM
10/23/14 06:44 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
A lot happens in 45 years, but I've seen a large number of '69 b-bodies with the inertia ring. Locally there is a loaded numbers matching LA built '69 RR 383/4-spd/3.55s/buckets/console/N96 complete car in need of restoration has an inertia ring.
Re: 69 R/T drive shaft [Re: 6bblgt] #1689581
10/23/14 08:41 PM
10/23/14 08:41 PM
Indiana
68_661charger Offline
Indiana
What's the purpose of the ring? Does it have rubber in it?
Re: 69 R/T drive shaft [Re: 68_661charger] #1689582
10/23/14 09:09 PM
10/23/14 09:09 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
I have 3, 69 Coronet R,T's and all have the ring and all are OE drive shafts. Spd 8-68 323 auto. SPD 4-69 410 dana 4 spd. and SPD 6-04 354 dana 4 spd.
HEMI,S ARE FOREVER!!!
Re: 69 R/T drive shaft [Re: 1969 HEMI R-T] #1689583
10/24/14 11:20 AM
10/24/14 11:20 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Thanks, guys. I was pretty sure it was original to the car.
Re: 69 R/T drive shaft [Re: 68_661charger] #1689584
10/25/14 03:17 AM
10/25/14 03:17 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here is info from the '69 FSM. Not a lot of explanation. Basically says there are 4 types of driveshafts and "certain applications" use an inertia ring.
Don't know for sure, but don't think there is rubber in it.
