Header size? #1689505
10/23/14 12:50 AM
10/23/14 12:50 AM
State, country, etc.
gss Offline OP
gss  Offline OP
I have a mild 400, .528 solid cam, old DC Stage 4 heads. I can get a good deal on a set of headers with 2 1/8 primaries. What would I be giving up it terms of torque and horsepower using these headers vs a 1 3/4" primary? Full exhaust street car. Thank you
Re: Header size? [Re: gss] #1689506
10/23/14 01:46 AM
10/23/14 01:46 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Stick with the 1-3/4", or 1-7/8" at most, for what you described.
Re: Header size? [Re: gss] #1689507
10/23/14 02:57 AM
10/23/14 02:57 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
If you can get a good deal on them, I'd consider buying them and see if you can sell them to a racer, or trade them for some 1-3/4" primary headers. They'd cost a ton of torque on that combo.
Re: Header size? [Re: StealthWedge67] #1689508
10/23/14 03:16 AM
10/23/14 03:16 AM
gss Offline OP
gss  Offline OP
I understand all that. I just want to know the difference in horsepower and torque. There has to be countless dyno tests and dragstrip tests.
Re: Header size? [Re: gss] #1689509
10/23/14 09:11 AM
10/23/14 09:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I went from 1 3/4 to 2" and only picked up 1.5mph. But I have a little more motor than you. 2 1/8 are huge and might be a pain to deal with. You can get a brand new set of 1 3/4 from Summit for $150 or less.
Coming soon!!!!
Re: Header size? [Re: gss] #1689510
10/23/14 10:18 AM
10/23/14 10:18 AM
an8sec70cuda Offline
gss...I agree 100% w/ what was said already, a 1 3/4" or 1 7/8" header is what you need. Those 2 1/8" headers will kill the lowend on your motor.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Header size? [Re: an8sec70cuda] #1689511
10/23/14 10:25 AM
10/23/14 10:25 AM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
How do you guys come up with header sizes? Is there a formula that you use?
Greg
Cost is irrelevant, making memories is far more valuable!biggrin
Re: Header size? [Re: 1320Dart] #1689512
10/23/14 10:47 AM
10/23/14 10:47 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Yeah........it's called Mr. Peabody.
He has a program ( pipemax ? )and was very generous in his assistance with mine and many others.
The Wallace calculator can give you a good baseline too.
http://www.wallaceracing.com/header_length.php
Re: Header size? [Re: tubtar] #1689513
10/23/14 11:31 AM
10/23/14 11:31 AM
Idaho
1320Dart Offline
1320Dart  Offline
Idaho
Thank you tubtar
Greg
Re: Header size? [Re: gss] #1689514
10/23/14 11:51 AM
10/23/14 11:51 AM
BradH Offline
BradH  Offline
I'm sure there are some magazine tests done on header sizes that will give you a reasonable idea. Google can probably turn up a few.
Regardless, a header way too big for any given combination kills the torque curve... and the combination you described can't afford to give up torque with only 400 cubes.
Re: Header size? [Re: BradH] #1689515
10/23/14 12:09 PM
10/23/14 12:09 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Exactly!!! I will post some tests I ran and show you. Too large a header basically leaves a huge hole in the torque curve right where you will need it.
Keith
Re: Header size? [Re: gss] #1689516
11/03/14 04:32 PM
11/03/14 04:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For your mild street car you would be giving up a lot
of torque with 2 1/8 pri. and mainly where you would
need it... 1 3/4 would work great for the street..
if you can.. set the collector length to about 18"
from the end of the primaries.. also measure the distance
to the front wall of the muffs... they should hopefully
be in multiples of that 18"(as in 18" 36" an so on)
for the best torque... in most cases(if not all) the
pri length is too long and the collector is to small
in dia and length).. if its 3" dia a 3.5" is normally
better but being a street car I wouldnt worry about it
Re: Header size? [Re: MR_P_BODY] #1689517
11/03/14 05:27 PM
11/03/14 05:27 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree you dont want that big a tube header on your combo. I used 1-3/4 on my old mild 440 combo and it dipped in the 11.40's with a full exh when it was in my 63. You can get Hedman 1-3/4 for a good price as thats all you need for your combo as like everyone says the large tubes will hurt the low end torque alot. Ron
Re: Header size? [Re: gss] #1689518
11/04/14 12:51 AM
11/04/14 12:51 AM
NC
440Jim Offline
440Jim  Offline
NC
As others have said, you would get killed in torque below 5500 rpm. And below 4000 rpm would be really bad. There is no way I would run a header that big in dia in your combo.
Re: Header size? [Re: 440Jim] #1689519
11/04/14 02:17 PM
11/04/14 02:17 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
With a full exhaust system i don't see a problem myself. Racing is a different story for diameter
Re: Header size? [Re: Mopar-Al] #1689520
11/04/14 04:53 PM
11/04/14 04:53 PM
gss Offline OP
gss  Offline OP
A little more information: These are high end custom fenderwell headers with a custom exhaust system. Cost to replace would be around $3000. It would be nice if they were a little smaller, but I think I will eventually build more cubic inches so hopefully it will be fine.
Re: Header size? [Re: gss] #1689521
11/05/14 12:18 AM
11/05/14 12:18 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
yep buyem and grow into them
