I have a 65 coronet convertible with a white top. Its top was bad when I got the car. I replaced the top with one from Legendary. Not super happy with it. The under side was black not white like the original. This made me rattle can black the header and bows. The seams on the top were not smooth they have wrinkles in them. No amount of stretching or heat would remove them. I see this every time I get in the car when the top is up. I also bought a new boot. My original was fine but it had shrunk, putting extra stress on the clips and molding. The new one from legendary was worse. These are some things to look for when buying a new replacement top. If I were you keep what you got as long as you can.
You might be able to talk an upholstery shop in replacing the material above the window. You need to tell them you want to preserve the original top. Because they will want to sell you a new top install.
I have never seen a chrome strip like the one on you car before. Maybe some one has gotten under there and fixed the rear window before.
