Transbrake/904 #1689350
10/22/14 09:21 PM
10/22/14 09:21 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I've rebuilt about a dozen torque flites mostly being stock rebuilds and shift kits
I'm about to build a 904 with a transbrake, what mods can I do or need to do to the internals of the Trans for the brake?
Re: Transbrake/904 [Re: RV2] #1689351
10/22/14 09:38 PM
10/22/14 09:38 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
There are lots of posts about this but I'll throw these out there.
Front drum w/ 5 dics Scarf cut sealing rings w/ stock drum chrome w/ alum drum
Multi pak front clutch springs
Top quality bands & clutches red? I don't remember my clearance but I'm thinking .008-.010 per disc
move the vent to the rear
Needle bearing output shaft support
If your over about 650 hp billet input & output shafts
Lots of line pressure 175 is what mine is and its maxed out w/ a HD spring,
There's more but this is a start
Several moparts sponsors can supply what you need. A&A TCS protrans
Re: Transbrake/904 [Re: DavidDean] #1689352
10/22/14 10:44 PM
10/22/14 10:44 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Should have a trans brake converter which has a steel stator or this can happen. Change from slot drive to the a500 flat drive pump drive. Billet low rev & kick down servo. Wide kickdown band.
Re: Transbrake/904 [Re: RV2] #1689353
10/24/14 11:46 PM
10/24/14 11:46 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
BTT
