45 RFE no reverse #1688988
10/22/14 01:00 PM
10/22/14 01:00 PM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
03 Jeep Liberty, no reverse, came back for awile then lost reverse again. No codes. Replaced soleniod pack, found accumulator plate bent and distorted. straightened and replaced missing screws. I also replaced the three seals between the valve body and trans case. No help, still no reverse. What next? I have rebuilt several 727s before but never in a 45 RFE.
Lee
Re: 45 RFE no reverse [Re: Lee] #1688989
10/22/14 03:19 PM
10/22/14 03:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That trans has a dedicated Reverse clutch, an air test might pinpoint it as the problem.
Re: 45 RFE no reverse [Re: Lee] #1688990
10/22/14 03:22 PM
10/22/14 03:22 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
45RFE ( and it's variants ) share nothing with a 727 ( and it's variants) This thing needs all kinds of special tools to overhaul. especially the tool to install the ft pump cover
45RFE is basically a 604 based transmission turned lengthwise.
IMO, have it ck'd with a DRB and do a clutch test and a CVI test ,,but my gut says it needs opened up.
Re: 45 RFE no reverse [Re: gtx6970] #1688991
10/23/14 12:04 AM
10/23/14 12:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
From what I remember the 45RFE needs no electronics for reverse as its one of the limp mode gears and in reverse all electronics are off as its all mechanical and hydraulic. And it uses the reverse clutch and the low/reverse clutch. I remember some of them breaking the screws in the acumulator plate and leaking fluid internaly past some of the acumulators causing pressure drop in some gears. I would pull the valve body and and air test the reverse clutch as John said. Its a good idea to check codes also. You may have to pull the trans to fix it. Ron
Re: 45 RFE no reverse [Re: 383man] #1688992
10/23/14 11:58 PM
10/23/14 11:58 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
The reverse and low reverse clutches are on in reverse. I would suspect the reverse clutches, fairly typical.
Do yourself a favor and install a Transgo Kit which will come with a heavier accumulator plate for the VB, but most importantly will come with a spring and ball to replace the converter limit valve assy in the pump which will be worn out.
Also, find a reputable trans shop to install an oversize switch valve plug assy in the VB, major wear there which will eventually kill the OD clutches.
Yes, it is coming out.
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 45 RFE no reverse [Re: zzyzxpat] #1688993
10/26/14 06:38 PM
10/26/14 06:38 PM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
Thanks for the replys..
Trans is out and apart...
All clutchs air checked good and clutchs look great.
Accumulator plate was badly bent and distorted. Broken screws but no screw heads in the pan. someone was in here before me. Am I missing something in the valvebody? Item #14 low/rev switch valve or # 15 low/rev switch valve bore plug. I only have one part here.
Re: 45 RFE no reverse [Re: Lee] #1688994
10/26/14 06:39 PM
10/26/14 06:39 PM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
What was in my valvebody....
Re: 45 RFE no reverse [Re: Lee] #1688995
10/26/14 06:41 PM
10/26/14 06:41 PM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
Close up....
Is this the low/rev switch valve or the low/rev switch valve bore plug?
Re: 45 RFE no reverse [Re: Lee] #1688996
10/26/14 11:55 PM
10/26/14 11:55 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Where is the plug, # 15?
Pat
Re: 45 RFE no reverse [Re: Lee] #1688997
10/26/14 11:57 PM
10/26/14 11:57 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
A Transgo Kit will give you a new #14 and 15 FYI.
Pat
Re: 45 RFE no reverse [Re: zzyzxpat] #1688998
10/27/14 12:57 AM
10/27/14 12:57 AM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
Pat
Thanks for the info, which kit, the 45RFE-HD or the SK-45RFE. Which one do you recommend?
Lee
Re: 45 RFE no reverse [Re: Lee] #1688999
10/27/14 11:07 PM
10/27/14 11:07 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
The SK will do you fine.
Re: 45 RFE no reverse [Re: zzyzxpat] #1689000
11/02/14 01:19 PM
11/02/14 01:19 PM
Chicago
Lee Offline OP
Lee  Offline OP
Chicago
Thanks for all the help. Trans is back together and works great!!!!!!!!!!!
Lee
