Drag Pak intake plenum specs #1688883
10/22/14 07:24 AM
10/22/14 07:24 AM
Melbourne.....Oz-land
Moparmal Offline OP
Moparmal  Offline OP
If someone could measure the width, height and length of the Drag pak intake plenum...external measurements would be fine - I'd greatly appreciate it.
I want to compare plenum volume with my "modified" Modman.
Thx in appreciation
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688884
10/22/14 08:16 PM
10/22/14 08:16 PM
Moparmal Offline OP
Moparmal  Offline OP
Bumpity..
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688885
10/23/14 04:11 AM
10/23/14 04:11 AM
Moparmal Offline OP
Moparmal  Offline OP
It would really help me as I need to compare plenum volumes btwn my modified intake and what we know works for a carb inducted Gen 3
Maybe now people know the reason for my asking.....
Its just 3 lil measurements.
Sixpackgut? Steff??? Maybe someone can step up? :
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688886
10/23/14 05:31 AM
10/23/14 05:31 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Wouldn't runner length be important too?
Mopar to the bone!!!
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688887
10/23/14 06:37 AM
10/23/14 06:37 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
I can measure it this evening, after work.
Re: Drag Pak intake plenum specs [Re: STEFF] #1688888
10/23/14 07:29 AM
10/23/14 07:29 AM
Moparmal Offline OP
Moparmal  Offline OP
Thanks Steff...cheers mate!
72 Swinger - You are correct - but the issue is more complex than just the intake.....
What I want to do first is make sure the plenum volume is not crazy....
Ive already put a temp gun on the exhaust headers and the fuel distribution has improved big time with the divider.
Once I get the Carb to Plenum ratio sorted - I can worry about the bear in the room...which is camshaft related and not an easy fix with factory slugs..
Needless to say....Im not running a cam that's 8 degrees retarded out of choice....but that's where we're at with most "off the shelf" cams and factory slugs.
Thx for your interest.
Re: Drag Pak intake plenum specs [Re: STEFF] #1688889
10/25/14 02:33 AM
10/25/14 02:33 AM
Moparmal Offline OP
Moparmal  Offline OP
Paging Steff - Did u have a chance to take a measurement?
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688890
10/25/14 03:57 AM
10/25/14 03:57 AM
P
Porter67 Offline
Porter67  Offline
P
I would like to know what your coming up with. And what % of PV to CI you think you need.
A multi carbed mod man does well with the theory of equal plenum volume in relationship to the cubic inches of the motor.
Im at 414 cubic inches and 390 cubic inches of plenum volume using the std. way many measure, which is like 96% shooting for 100%.
I know many are going to say wtf, but its a reality. Using a multi carb setup. And if done right can be as responsive as fuel injection.
With a .660 lift solid cam with with aggressive lobes that would run with a roller with near the same specs 1.9HP per cubic inch was the end result.
But this being the mopar world few will think out of the box, the best thing anyone could do is toss every single "How to build a xxx mopar" book in the crapper and look at other areas and brands of motorsports.
The mod man is a awesome manifold but very few really understand it.
But from ootb to a good end result is a long haul time wise.
I have more or less made mine into a one piece unit.
The detractors who do not understand or have even seen one will say the bottom flat floor will puddle fuel and not flow hitting a flat bottom.
Well they need to look at a oem dual plane as its dead end flat where the mod man is 1/4 inch higher on the plenum and gently slopes to the runners.
Also many complain the runners are two short, refer back to a oem manifold and 4 of the 8 are shorter in length and the others are equal.
I wish you the best of luck, there are many other ways to increase PV on the mod man if needed and you don't have to go up.
The best thing about a LA unit as I built is its within 1/4 inch of the height of a oem dual plane.
Its a proven setup, just freshened for another project.
The mod man concept is not new, a large plenum short runner unit was used and raced by fords long long ago.
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688891
10/25/14 06:00 AM
10/25/14 06:00 AM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
Mal,
What sort of divider did you use ? I used a a trianguler insert running the length as a semi divider. Took out about 15-20% of the volume. Have not tried since doing motor mods a year ago
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688892
10/25/14 08:09 AM
10/25/14 08:09 AM
STEFF Offline
STEFF  Offline
I will this afternoon. Sorry for the delay.
Re: Drag Pak intake plenum specs [Re: Porter67] #1688893
10/25/14 06:12 PM
10/25/14 06:12 PM
Moparmal Offline OP
Moparmal  Offline OP
Porter67 - Im sorry but I cant agree - any intake that shows:
- a 4mph improvement going from a single to dual carbs, and
- a 2mph improvement just thru the addition of a 1/2" wide block of aluminium,
,,,,,,,,isnt a 'great intake' - especially when you consider this comparison was also verified on the Dyno. The only other change being an extea 2 degrees INITIAL timing.....
I appreciate your thoughts on plenum volume but Id like to do the comparison anyhow,
FWIW I saw no evidence of fuel "pooling" when I had the top plate off,
TEX - As stated - a full height 1/2" wide full length block of aluminium
At the time I did the testing the divider was shadowing the venturi holes in the top plate - so less than ideal.
Since then Ive profiled the top edge to allow a straight shot from the carbs into the plenum with no interference
Steff - No rush man.....whenever you can get to it...
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688894
10/25/14 09:40 PM
10/25/14 09:40 PM
STEFF Offline
STEFF  Offline
Here you go.
Re: Drag Pak intake plenum specs [Re: STEFF] #1688895
10/25/14 11:06 PM
10/25/14 11:06 PM
Moparmal Offline OP
Moparmal  Offline OP
Thx Steff....thats better than I expected - Ill do the math and post the results...
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688896
10/26/14 02:13 AM
10/26/14 02:13 AM
Sydney,Australia
Sydney,Australia
Mal,
I remember Indy saying i would need more rpm,maybe towards 6700. Seems most agree short runner equals higher rpm,plus volume too big equals low rpm performance loss. Thats why mine is off,be fine on 500ci
I filled my intake with water,just over 5 litres
Tex
New best MPH 130.32
Re: Drag Pak intake plenum specs [Re: tex013] #1688897
10/26/14 04:47 AM
10/26/14 04:47 AM
Moparmal Offline OP
Moparmal  Offline OP
Cheers Tex...Did that 5 litres include the runners?
As far as the intake - I can tell you my G3 is still making power at 7000 - but part of that is about the retarded off the shelf cams they sell for these G3s....
It makes me wonder if the sluggishness off the mark is all intake related....or the 114 ICL has kicked me in the nuts while I was worrying about the right jab from the intake signal.....
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688898
10/26/14 06:55 PM
10/26/14 06:55 PM
Sydney,Australia
Sydney,Australia
Mal,
that included runners - I bolted a plate across each intake face .
On the street the intake seemed fine - at the track a different story . Killed the 60' but ran same mph. On the dyno made similar power to the M1 single plane I was running at the time . Could not get it to richen up enough . I have since put better flowing heads that woke up the motor but have not retried the modman .Maybe next season
Tex
New best MPH 130.32
Re: Drag Pak intake plenum specs [Re: tex013] #1688899
10/26/14 07:21 PM
10/26/14 07:21 PM
Moparmal Offline OP
Moparmal  Offline OP
Single or dual carbs? - my 60 improved with duals...but the divider was the real improvement .
Still not great at 1.83... But part of that is cam related also...
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688900
10/26/14 10:54 PM
10/26/14 10:54 PM
Sydney,Australia
Sydney,Australia
dual quad setup. even added 4 hole spacers helped a bit but added volume back in
may simply be too much volume for my cubes and rpm range
Tex
New best MPH 130.32
Re: Drag Pak intake plenum specs [Re: tex013] #1688901
10/27/14 12:30 AM
10/27/14 12:30 AM
Moparmal Offline OP
Moparmal  Offline OP
I reckon you're right...thats why I want to do a plenum volume comparison.....but remember...its also those huge head ports as well!
Re: Drag Pak intake plenum specs [Re: Moparmal] #1688902
10/27/14 02:05 AM
10/27/14 02:05 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
You put a new hemi in your charger? Care to trade it to me now?
