426 Hemi i.d. pad #1688772
10/21/14 10:36 PM
10/21/14 10:36 PM
MoPar Offline OP
MoPar  Offline OP
Could someone decipher this for me, the cast date on the side of the block is 5-4-64.
Re: 426 Hemi i.d. pad [Re: MoPar] #1688773
10/21/14 10:51 PM
10/21/14 10:51 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
That is a V=1964, H= hemi, 426 cid and a HC= high compression.
the 6-1 is the assembly date. That cast date is a little earlier. You have a 1964 race hemi block. It worth some money to guy wanting to restore one of those cars.
Re: 426 Hemi i.d. pad [Re: fastmark] #1688774
10/21/14 11:05 PM
10/21/14 11:05 PM
MoPar Offline OP
MoPar  Offline OP
Thanks, do any of the other markings have any significance ?
Re: 426 Hemi i.d. pad [Re: MoPar] #1688775
10/21/14 11:15 PM
10/21/14 11:15 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I think the 08 stands for 8th motor that day
WT= Water Tested. I appears the worker had no "T" (or didn't bother) and used a dash twice to make the T, but I'm no expert.
Edit: The big circle with the two numbers (kinda looks like somthing-3) I could only speculate.
