R3 dry sump setup #1688534
10/21/14 08:29 AM
10/21/14 08:29 AM
West Milton,Pa
cermac Offline OP
cermac  Offline OP
West Milton,Pa
Who's products and where to buy using a six stage pump on 775 hp 72 abody drag car!
Re: R3 dry sump setup [Re: cermac] #1688535
10/21/14 09:10 AM
10/21/14 09:10 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Peterson has everything you need except the oil pan. You can modify an after market pan to work, depending on what mains you have there was some oil pans for sale on racing junk. For an oil tank you won't need a monsterous one like the circle track stuff, an 8qt should be fine in a drag car.
Hope you don't have the factory K and steering
Re: R3 dry sump setup [Re: SpareParts] #1688536
10/21/14 12:24 PM
10/21/14 12:24 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Sorry if OT, what purpose do the bigger multi gal tanks then serve for circle track, better air separation, more capacity for longer runs, offesetting small leaks, thermal (they already run coolers?), etc?
Re: R3 dry sump setup [Re: jcc] #1688537
10/21/14 02:28 PM
10/21/14 02:28 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Not really sure why they do it but some of their tanks are like 20qt capacity... maybe for cornering??
Re: R3 dry sump setup [Re: SpareParts] #1688538
10/21/14 02:49 PM
10/21/14 02:49 PM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
More oil means less heat in the oil over a longer period.
AutoVerde and Dailey sell the best pumps IMO. Peterson has some good products as well. I like their tanks for sure.
Re: R3 dry sump setup [Re: Al_Alguire] #1688539
10/21/14 04:07 PM
10/21/14 04:07 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
PM Brett Miller (W5Dart66), he had a few craftsman truck motors that he converted to wet sump. He may have everything you need.
Re: R3 dry sump setup [Re: cermac] #1688540
10/21/14 07:03 PM
10/21/14 07:03 PM
West Milton,Pa
cermac Offline OP
cermac  Offline OP
West Milton,Pa
Was looking at Barnes pump,(used). Hardest part is pan. Can't find any used for 340 mains. Will by new but what manufacturer ? Do have a qualified fabricator if need repaired for some reason!
Re: R3 dry sump setup [Re: cermac] #1688541
10/21/14 08:39 PM
10/21/14 08:39 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
The pans are fairly simple, just make sure you're picking up from the lowest point of the pan. Most just look like a box
Re: R3 dry sump setup [Re: SpareParts] #1688542
10/22/14 06:20 AM
10/22/14 06:20 AM
Finland
mafo Offline
mafo  Offline
Finland
If you have stock steering fitting a 6 stage pump will be difficult, I use a moroso 5 stage and relocated it to the right side of the engine
with the stock K member you probably have to make a custom oil pan
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: R3 dry sump setup [Re: mafo] #1688543
10/22/14 09:37 AM
10/22/14 09:37 AM
West Milton,Pa
cermac Offline OP
cermac  Offline OP
West Milton,Pa
We are doing a strut - rack front this winter. Car is alcohol mechanical injection with Ron's toilet. Pump is on drivers side motor plate. Have to mount oil pump on pass side. Pan is biggest decision as there are not many off shelf I can find. All Chevy and Ford as usual!
Re: R3 dry sump setup [Re: cermac] #1688544
10/22/14 12:08 PM
10/22/14 12:08 PM
Finland
mafo Offline
mafo  Offline
Finland
