Re: R3 dry sump setup
[Re: SpareParts]
#1688538
10/21/14 02:49 PM
10/21/14 02:49 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
More oil means less heat in the oil over a longer period.
AutoVerde and Dailey sell the best pumps IMO. Peterson has some good products as well. I like their tanks for sure.
[Re: SpareParts]
#1688542
10/22/14 06:20 AM
10/22/14 06:20 AM
Posts: 1,019 Finland
mafo
Finland
If you have stock steering fitting a 6 stage pump will be difficult, I use a moroso 5 stage and relocated it to the right side of the engine with the stock K member you probably have to make a custom oil pan
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
