Cylinder Head and piston combo #1688422
10/20/14 11:51 PM
10/20/14 11:51 PM
budd12 Offline OP
budd12  Offline OP
Can you install 572-13 heads on a 572ci in motor that had 440-1 heads on it.
Re: Cylinder Head and piston combo [Re: budd12] #1688423
10/21/14 02:20 AM
10/21/14 02:20 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Your pistons have different valve pockets, due to the different valve angles. Depending on your cam specs you will run out of radial valve clearance real fast.
Other than that.....Todd
Re: Cylinder Head and piston combo [Re: sasquatch] #1688424
10/21/14 10:21 AM
10/21/14 10:21 AM
budd12 Offline OP
budd12  Offline OP
thanks for the reply, Could the pistons be machined to obtain the proper valve clearance?
