Cylinder Head and piston combo #1688420
10/20/14 11:40 PM
10/20/14 11:40 PM
budd12 Offline OP
budd12  Offline OP
Can you install 572-13 heads on a 572ci in motor that had 440-1 heads on it.
Re: Cylinder Head and piston combo [Re: budd12] #1688421
10/21/14 03:16 AM
10/21/14 03:16 AM
Call Indy and ask them What size valves are in the new heads and are they bigger than the old 440-1? If so I would always check for piston to valve and valve to cylinder wall clearances Even if the new heads have the same size valves I would call Indy and make sure the valve centers are not wider and on a different angle to the piston tops when comparing the new 572-13 heads to the 440-1
