Small Block valve placement #1688371
10/20/14 07:01 PM
10/20/14 07:01 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
How does the valve positioning change in aftermarket heads compared to afactory head? I have been told that the Indy heads have the exhaust valve moved across, but what about W8 & W9?
Cheers
Alan Jones
Re: Small Block valve placement [Re: LA360] #1688372
10/20/14 08:20 PM
10/20/14 08:20 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Cheers
Yes, about .120" or so IIRC, intakes are also moved the same direction .060"
Re: Small Block valve placement [Re: LA360] #1688373
10/21/14 08:28 AM
10/21/14 08:28 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Cheers
I believe the book How to big inch a small block Moparts gives you the spacing on most of the different casting available. Matt
