Small Block valve placement
#1688371
10/20/14 07:01 PM
10/20/14 07:01 PM
Posts: 6,142 Melbourne , Australia
LA360
How does the valve positioning change in aftermarket heads compared to afactory head? I have been told that the Indy heads have the exhaust valve moved across, but what about W8 & W9? Cheers
Alan Jones
Re: Small Block valve placement
[Re: LA360]
#1688372
10/20/14 08:20 PM
10/20/14 08:20 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
Yes, about .120" or so IIRC, intakes are also moved the same direction .060"
[Re: LA360]
#1688373
10/21/14 08:28 AM
10/21/14 08:28 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
I believe the book How to big inch a small block Moparts gives you the spacing on most of the different casting available. Matt
