reproduction wiring harnesses #1688150
10/20/14 10:15 AM
10/20/14 10:15 AM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
www.narragansettreproductions.com
has anyone ever used this company?
looks like they could make some accurate harnesses.
all the best
frank.
Re: reproduction wiring harnesses [Re: 1cuda] #1688151
10/20/14 10:27 AM
10/20/14 10:27 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Never used them, but they say the right things on their web page . . . would be interesting to hear how they do if you use them.
I bought all mine through M&H (ordered through Year One with a discount coupon). The harness recieved would have worked fine, but there were a couple small details that were different. I documented the differences and sent it to M&H who offered to make the correction if I sent in my original harness.
Harness returned is outstanding !
Good luck whatever you decide.
Re: reproduction wiring harnesses [Re: 1cuda] #1688152
10/20/14 10:43 AM
10/20/14 10:43 AM
O
otter440 Offline
otter440  Offline
O
I had them make me all the harnesses for a 1968 charger you have to send them all the ends We had a lot of problems with the harnesses so I would not use them again.
Re: reproduction wiring harnesses [Re: otter440] #1688153
10/20/14 11:47 AM
10/20/14 11:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
And their prices are higher than M&H/Year One harnesses
Re: reproduction wiring harnesses [Re: DAYCLONA] #1688154
10/20/14 07:59 PM
10/20/14 07:59 PM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
thanks for the replies-that clears that question.
all the best
frank.
Re: reproduction wiring harnesses [Re: 1cuda] #1688155
10/21/14 11:26 AM
10/21/14 11:26 AM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
i used them once to rewrap my original tail light harness in that webbed cloth material.(not sure what the exact name of material is). they did a great job and it was a fast turnaround. apparently they are one of the few companies that have the machine that can wrap them in the OE type cloth. They said the machine dates back to the 20's and still running fine. however i cant verify their electrical work since i did not buy a harness from them.
Re: reproduction wiring harnesses [Re: 70plymA34] #1688156
10/21/14 12:03 PM
10/21/14 12:03 PM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
thanx for that-the missing oem type cloth wrap is most disappointing about reproduction harnesses.
