Re: how strong are the dana 60 posi factory posi units?
[Re: hp340nos]
#1687532
10/19/14 02:06 AM
10/19/14 02:06 AM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
curious on how much hp and torque the dana 60 style posi can handle?before a spool is needed?thanks
Which Dana 60 SURE GRIP , there are 2 types ????
[Re: JohnRR]
#1687533
10/19/14 03:26 AM
10/19/14 03:26 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
What Cab said. It's about the axles at your stage. Since you stated the sure grip bolts together that's a power loc -- the stronger of the two
I don't know what Chevy used for d60's - dodge used 30 spline axles and ford used 16 spline and then later 30 spline The side gears can be changed so if you want to step up to 35 the gears aren't terribly expensive My truck 60 had a 30 spline trac loc and I would estimate that 450 hp would be max on that unit. ( depending on weight and traction) I've since sold the traclock and bought a power lock from a older ford - swapped the side gears to 30 spline and plan to use my 8 3/4 axles. My car will eventually be in the 500-600 hp range and I feel safe at that level in my 3500 lb b body. I am sure that with 35 spline aftermarket axles you can raise that measurably but I'm not experienced at that level
[Re: hp340nos]
#1687535
10/19/14 09:15 AM
10/19/14 09:15 AM
Posts: 2,926 A shed in England
Tig
A shed in England
We've been mid 9's @ 3850lbs. Guessing 850 ish Hp and maybe a little over 700ft/lb Ours was a bolt together powerloc. After the Crown wheel and pinion recently let go, (12 year old 4:10 street gears), we've recently swapped over to a detroit locker and pro gears for the new motor (Dyno'd @ 1048hp and 950ft/lb) I don't really want to use a spool if I can help it. The powerloc was rebuilt and now resides in a buddies '62 pro street Impala running low 10's
EDIT: BTW car has 35 spline axles, 10.5 tyre and is footbraked.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: NTOLERANCE]
#1687536
10/19/14 12:00 PM
10/19/14 12:00 PM
Posts: 6,840 The Swamp
Sixpak
The Swamp
When you say you can change the side gears to accept a 35 spline axle, would it be the same diameter 35 spline axle that might go into a spool? If I remember right a 35 spline axle, at least for an 8 3/4, meant for a spool is considerably thicker.
[Re: hp340nos]
#1687537
10/19/14 12:14 PM
10/19/14 12:14 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I am glad to see someone ask this question, as I am curious myself!? The D60 in my car is from a Ford truck. It was an open rear with 4.11 gears, so I bought a rebuilt sure grip from my chassis man, and he ordered the 35 spline axles for me. I don't know which unit I have, but he said it is the stronger one. We only have 15 runs on the car, but it is working fine thus far. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: hp340nos]
#1687539
10/21/14 10:16 AM
10/21/14 10:16 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
I think member 572charger still has the factory suregrip (powerlock) in his '68 charger that runs 8.90s at 3900#. The powerlock (bolt together unit) is the stronger of the 2...the other being the tracklock. The powerlock is physically bigger, much bigger and heavier, than a tracklock. The tracklock kinda looks like an open diff. at first glance. Dr. Diff has the kit needed to convert a powerlock over to 35 spline. I used one when I converted a truck Dana for my dad's '69 road runner. Very nice kit and easy to do.
[Re: 74yellowduster]
#1687543
10/24/14 01:03 AM
10/24/14 01:03 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I use standard gear lube with the Mopar additive.
