Gen 3 Hemi vs. LA 340 weight?
#1687172
10/18/14 02:35 AM
10/18/14 02:35 AM
Posts: 2,432 NorCal
RylisPro
NorCal
Was doing some research and found the FABO thread http://www.forabodiesonly.com/mopar/archive/index.php/t-106670.htmlIt says Gen 3 Hemi's weigh 533 lbs. & LA 340's weigh 525 lbs. Is this fairly accurate? I would figure that the LA 340 weight is with iron heads and intake. My engine has alum. heads and intake though. Anyone know accurate weights on a Gen 3 Hemi and an alum. top end 340? Thanks
Re: Gen 3 Hemi vs. LA 340 weight?
[Re: RylisPro]
#1687173
10/18/14 02:41 AM
10/18/14 02:41 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
They are over 500 lbs. for sure. The blocks are freakin heavy!
Mopar to the bone!!!
[Re: RylisPro]
#1687176
10/18/14 10:33 AM
10/18/14 10:33 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Bare 6.1 block on my scales is 190-195 lb.
So maybe 30 lb heavier than a 340 block and 30 lb lighter than a 440 block
I don't think you'll see much weight difference between the three when set up similarly.
The aluminum block is 75-100 lb less than the iron block. $4300. More bore available.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: 70blackfish]
#1687178
10/18/14 04:33 PM
10/18/14 04:33 PM
72Swinger
Nebraska
Im not going to a Gen III for the weight break lol.
[Re: 72Swinger]
#1687179
10/18/14 05:02 PM
10/18/14 05:02 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Me either, there are many...many other reasons to upgrade from an LA to a 3rd Gen.
[Re: RylisPro]
#1687180
10/18/14 09:53 PM
10/18/14 09:53 PM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
The Gen 3 Hemi 427 crate motors are (4.125 bore x 4.00 stroke) all aluminum. Supposedly 100 lbs. less
Lets call it a 426. I dont care if its 1cid bigger... 427 is a Chevy/Ford engine.
190lb blocks? Christ. Things are supposed to get BETTER with technology... not worse. Who thought this one through in the design stages? You can find big block blocks that weigh that if you weigh a few...
I thought those new 7L hemis weren't available?
[Re: Pale_Roader]
#1687181
10/18/14 10:00 PM
10/18/14 10:00 PM
72Swinger
Nebraska
Ill take a heavy block any day of the week that doesnt have cap walk and try to spit the crank out when you get towards 700hp.
[Re: GoodysGotaCuda]
#1687184
10/18/14 10:07 PM
10/18/14 10:07 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Hey Goody do you have your car's weight before you pulled your LA small block? When you put in your Gen 3 and your T56 Magnum, please weigh your car. That's the real weight I want to know
[Re: RylisPro]
#1687185
10/18/14 11:08 PM
10/18/14 11:08 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'll let you know. My iron headed/alum intake 318/904 weighed as follows. I'll be at least a year out on my swap.
[Re: 72Swinger]
#1687188
10/19/14 05:26 AM
10/19/14 05:26 AM
Pale_Roader
Swears too much
Swears too much
Ford's 20 year old 'Teksid' aluminum 4.6 block (96-99 Cobra) weighs about 90lbs, and is tried, tested and true to 1400HP. Their later ('01) domestic block was 5lbs lighter and still good for 1000 or 1200HP... i forget. They're already getting staggering numbers from the new 5.0 Coyote blocks. You can keep your 200lb block... whoever came up with that one is still livin' on 70's time...
I had no idea they were so heavy. Would have figured Dodge would have gone aluminum by now too? Even for iron... that seems overly heavy.
[Re: RylisPro]
#1687189
10/19/14 05:30 AM
10/19/14 05:30 AM
Pale_Roader
Swears too much
Swears too much
Do you happen to remember how much gas you had in the tank at the time? Great info! 55/45 front rear at 3400 lbs. is pretty good for an E body!
Not bad at all. My bone stock survivor/stripper 70 6-cyl Challenger was 60/40 at 3000lbs...
[Re: Pale_Roader]
#1687190
10/19/14 09:04 AM
10/19/14 09:04 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I agree, production high hp aluminum blocks are out there for Ford and Chevy. Typical Mopar is always behind in some form or fashion...Unfortunately it's the best thing we have going at the moment.
