torque converter for 360 ? #168669
12/16/08 07:37 PM
12/16/08 07:37 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
I have a 70 Challenger with a 360 Engine and 727 Trans.
should the Torque Converter have weight on them or not? If so is there a diagram to see where?
Re: torque converter for 360 ? [Re: moparmikethree] #168670
12/16/08 07:51 PM
12/16/08 07:51 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
yes it does, But im not sure where exactly. ot you can purchace a B and M flex plate (10-279, i think )to use a nuetral ballance TC. I think mopar used to sell the weight with a template.
Re: torque converter for 360 ? [Re: Dakota_Don] #168671
12/16/08 08:01 PM
12/16/08 08:01 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If the converter has a drain it will have 1 weight on each side of the drain plug. Those without a drain have 1 weight = to the 2 weights on the ones with a drain.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
