#3549699 Challenger Hood Molding '71 ? #1686587
10/16/14 08:30 PM
10/16/14 08:30 PM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Is part #3549699 Challenger hood molding the later '71 style molding or the '70 only style? Thanks
Re: #3549699 Challenger Hood Molding '71 ? [Re: 44D6PAKCUDA] #1686588
10/16/14 09:11 PM
10/16/14 09:11 PM
USA
rftroy Offline
rftroy  Offline
USA
Parts book shows that as the 1970, non-TA part.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: #3549699 Challenger Hood Molding '71 ? [Re: rftroy] #1686589
10/16/14 09:13 PM
10/16/14 09:13 PM
So did the T/A use the later style trim that had the lip that went under the front of the hood?
Re: #3549699 Challenger Hood Molding '71 ? [Re: 44D6PAKCUDA] #1686590
10/16/14 09:23 PM
10/16/14 09:23 PM
USA
rftroy Offline
rftroy  Offline
USA
http://www.tuffwheelrestoration.com/hoodlipmolding.html
Try calling these guys. They can probably tell you the difference.
Robert
Re: #3549699 Challenger Hood Molding '71 ? [Re: rftroy] #1686591
10/16/14 09:27 PM
10/16/14 09:27 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
All 1970 Challengers used the same hood molding.
The T/As just used it with longer stud clips because the front lip on the 'glass hood is much thicker than the steel hoods.
The stud clips are easy to change out if needed.
Re: #3549699 Challenger Hood Molding '71 ? [Re: rftroy] #1686592
10/17/14 03:39 AM
10/17/14 03:39 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Robert
Odd they want $40 more for the T/A part w/o studs than the STANDARD Challenger w/o studs version.
Here's a #3549699 that I have just opened studs are 3/4" long (how long are the T/A pieces?). The original cellophane packaging is stuck to the face of the part, what's the least destructive way to remove it?
Re: #3549699 Challenger Hood Molding '71 ? [Re: 6bblgt] #1686593
10/17/14 12:10 PM
10/17/14 12:10 PM
pa.
dan9 Offline
dan9  Offline
pa.
Rubbing alchohol
Re: #3549699 Challenger Hood Molding '71 ? [Re: dan9] #1686594
10/17/14 02:37 PM
10/17/14 02:37 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Jim/Dan: These are the correct original factory clips used to mount these hood pieces. The one in front is an original off my car.
Re: #3549699 Challenger Hood Molding '71 ? [Re: m46rat] #1686595
10/17/14 03:17 PM
10/17/14 03:17 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Original for a 70 type molding like Dan posted, or/and a 71 molding that also has the ledge on the bottom?
Re: #3549699 Challenger Hood Molding '71 ? [Re: m46rat] #1686596
10/17/14 04:40 PM
10/17/14 04:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Dwight, what are those from? They do not look like they would work well with the foam insert inside the moulding, nor do they look like they would pull the moulding tight to the hood. Here's 2 used '70 mouldings I have with the same ~3/4" studs as the '78 dated NOS piece.
Re: #3549699 Challenger Hood Molding '71 ? [Re: 6bblgt] #1686597
10/17/14 10:50 PM
10/17/14 10:50 PM
m46rat Offline
m46rat  Offline
They were off an all original, untouched 70 318 car. They would be correct for 1970 only. 1971 had screws that held it in place along the bottom of the moulding that is unique to 1971. The original moulding did not have the foamy stuff inside it. Those Pal nuts held it in place just fine.
Re: #3549699 Challenger Hood Molding '71 ? [Re: m46rat] #1686598
10/28/14 10:13 PM
10/28/14 10:13 PM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
Does anyone know a source for these clips? I need a set for the trunk molding on my '70 Dart.
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
