Re: LX cars frame rust?
[Re: AMC400Mopar]
#1686504
10/17/14 02:40 AM
10/17/14 02:40 AM
Posts: 10,838 Freeport IL USA
poorboy
Freeport IL USA
My guess would be that since you live in Canada, and the car has never been driven in the winter, you have had some mice take up residence in your frame rails. Their urine is acidic and will eat the metal in your frame rails in a couple years. The close proximity of the rails to the converters would invite the little critters to the nice warm place, and then would bake the urine and nest into a nice frame rusting concoction. Is there a dusty, flaky dirt and grass/material, or cotton like fuzz clump inside your frame rails?
It will be interesting to see if the frame rail rust is a consistent with the LX cars.
The fix is going to be like any other frame rail replacement, pull the carpet and everything else off the floor, remove the rusted rail, fabricate a new rail, and weld it back in place. Then replace the removed interior. Gene
[Re: AMC400Mopar]
#1686506
10/20/14 03:45 PM
10/20/14 03:45 PM
Posts: 4,269 Canada
WO23Coronet
Canada
I've got an 05 R/T, next oil change I'll take a hard look, thx for the heads up, btw, is it on both sides?
[Re: AMC400Mopar]
#1686509
10/21/14 05:29 PM
10/21/14 05:29 PM
Posts: 105 ON, Canada
AMC400Mopar
ON, Canada
Here's a little better pic of the Left side. I will bring a real camera with me next time the car is up so I can get some clear shots. The damage is the same on both sides, right side being slightly worse.
[Re: AMC400Mopar]
#1686510
10/21/14 06:02 PM
10/21/14 06:02 PM
Posts: 16,094 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Wow, that's a new one on me. I had an '06 SRT8 and no rust anywhere for the 6 years of ownership, but I am in Florida.
I am on the LX forums very frequently and have not read of this being a common problem. Good Luck.
Facts are stubborn things.
[Re: AMC400Mopar]
#1686512
10/21/14 08:04 PM
10/21/14 08:04 PM
Challenger 1
Cincinnati, Ohio
While removing the dipstick tube so I could dig out a broken dipstick (plastic handle broke off...) on my stock 2005 Magnum RT I was shocked to discover heavy rust on both sides of the frame directly adjacent to the catalytic converters. The rust has nearly eaten through the frame at these spots! There is no rust anywhere else on my car, and it has never been undercoated or winter driven. The exhaust is all original. The stock cats never had heat shields and are located very close to the frame rails; it is my understanding that newer models have heat shields on the cats...I am guessing the heat cooked the paint and any factory rust protection off in these spots.
Is this common with other LX models (mag/challenger/charger) and how is it normally repaired? Should I contact Chrysler directly? Any advice would be great, thanks!
Thanks for the heads up, Hope you can get it repaired. The 1100 bucks starting to not sound so bad to me now...
[Re: Challenger 1]
#1686513
10/21/14 08:26 PM
10/21/14 08:26 PM
AMC400Mopar
ON, Canada
Does anyone with a newer 5.7 LX car know if there are heat shields on the cats? My '05 never had them, and after looking at pics online it is kinda hard to tell if they were added to newer models. Or maybe someone has access to a parts fiche? If they indeed did add heat shields later in production it's pretty obvious Chrysler knew this could be a problem. I also wonder if the six cylinder models have the cats as close to the rails as the hemi versions? Sorry to whine, I really love my car so this drives me nuts...
[Re: AMC400Mopar]
#1686520
10/23/14 03:11 PM
10/23/14 03:11 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
That's great that you have a dealership that does it's best to help the customer instead of blowing you off with "it's out of warranty".
[Re: larrymopar360]
#1686521
10/24/14 05:32 PM
10/24/14 05:32 PM
AMC400Mopar
ON, Canada
As the Niagara Chrysler service manager suggested yesterday (after my mechanical inspection) I took my Magnum in to the bodyshop today for an inspection by body techs. The two techs who inspected it were shocked at the damage. I was shocked at the repair quote---$8100!! I was told the engine, drivetrain, subframe, interior had to come out in order to properly replace the rotted sections of frame alongside the cats. They were impressed by the overall clean condition of my car, very sympathetic regarding the frame problem, and suggested I contact Chrysler Canada.
The Niagara Chrysler service manager had already sent in his photos and report yesterday, and suggested I contact Chrysler Canada directly this afternoon as he had not yet heard back from the district service manager.
When I called Chrysler Canada they told me even though my car is out of warranty they would like to further investigate the problem, and opened a Case File on the car. They said I should to expect to hear back from them on Monday. I hope that is a good sign.
I guess I'll wait and see what they say on Monday and go from there. All the Chrysler service managers, techs and even the woman on the phone at Chrysler Canada were excellent.
