Challenger firewall question. ? #168621
12/16/08 06:18 PM
12/16/08 06:18 PM
missouri, USA
moparmojo Offline OP
missouri, USA
Can someone please take a look at these pics and tell me if there is something odd about the blower motor set up on this car. Something doesn't seem right. Car is a 1970 challenger convertible. I have an air dash in the car, but I am not positive it was an original air car. These are older pics I downloaded as a group,from when I first attempted to clean up the engine bay, but a couple are of the area I am talking about.
Re: Challenger firewall question. ? [Re: moparmojo] #168622
12/16/08 06:28 PM
12/16/08 06:28 PM
Anchorage,AK
AK_JH27 Offline
AK_JH27  Offline
Anchorage,AK
I have a 71 convertible with Air and my firewall looks just like yours
Re: Challenger firewall question. ? [Re: AK_JH27] #168623
12/16/08 06:53 PM
12/16/08 06:53 PM
missouri, USA
missouri, USA
The things I wonder about are: is the blower motor suppose to be mounted on the outside?
It has some pretty visible seams or seam sealer, is this factory or where someone peiced in a blower motor?
Lastly, is it in the correct location? I always thought it looked a little too close to the passenger inner fender.
I mainly question this because the previous owner did a lot of really crude stuff to the car as it was previously painted up before I got it. (ie; shoddy body work and all).
Re: Challenger firewall question. ? [Re: moparmojo] #168624
12/16/08 08:09 PM
12/16/08 08:09 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
It's hard to see those pics but after a looking closely I see what you're asking...Yes, it looks like someone added the A/C blower motor section to your firewall...If it fits in the correct position in the heater box you should be OK...So are you saying that the section in question is seam-sealed in ??? .. The A/C blower motor does install from the engine compartment so you're safe there...There is a rubber seal that is installed on the A/C motor{mounts between the firewall and motor} and will have 3 rubber tabs and small metal washers to isolate the motor from the mounting nuts...
Re: Challenger firewall question. ? [Re: screamindriver] #168625
12/16/08 08:53 PM
12/16/08 08:53 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The blower motor on an A/C car installs from the engine compartment. A non A/C cars blower motor installs from the inside.
Re: Challenger firewall question. ? [Re: screamindriver] #168626
12/16/08 11:43 PM
12/16/08 11:43 PM
missouri, USA
missouri, USA
It appears as though seam sealer is around most of the blower motor. However, I will not know for sure until I clean all the paint away from that area. I could be fine with it, if I knew it was in the right area and only needed to be welded in, but I am not even sure of that. Maybe if someone had some basic measurements of it's location that would help.....anyone???
Re: Challenger firewall question. ? [Re: moparmojo] #168627
12/16/08 11:57 PM
12/16/08 11:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Note the radiator opening for a 22" radiator, an original AC car would have the opening for a 26" radiator.
Re: Challenger firewall question. ? [Re: Alaskan_TA] #168628
12/17/08 12:26 AM
12/17/08 12:26 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
looks off to me. here is a bad pic of the one in my 73 (which is an air car and has 26" radiator opening)
