piston rings #168532
12/16/08 03:13 PM
12/16/08 03:13 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
i`m putting together a 318, i have a set of hastings moly rings. while moving things around they slid out of the box and i`m not sure which is the top compression ring. one ring has a dot on it and is fully moly coated. the other has no dot and the edge is not moly coated. which is the top one?
Re: piston rings [Re: 65rbdodge] #168533
12/16/08 03:41 PM
12/16/08 03:41 PM
one ring has a dot on it and is fully moly coated. which is the top one?
those
Re: piston rings [Re: RapidRobert] #168534
12/16/08 03:45 PM
12/16/08 03:45 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Coated should be top.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: piston rings [Re: MoparforLife] #168535
12/16/08 04:24 PM
12/16/08 04:24 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
and remember the dot is the top of the ring...goes up on the piston
Tony
70 AARCuda Vitamin C
