'68 383 Barracuda pulleys #1684787
10/12/14 09:29 AM
10/12/14 09:29 AM
Michigan,United States
barracudadon383 Offline OP
I need the fan pulley and the crank pulley for my factory 383 Barracuda. I bought a fan pulley and it was the wrong one so I'm hoping to avoid that mistake again. Anyone know the sizes for them? No power steering or air...just a factory set-up. Thanks...
Learnin' the hard way...
Re: '68 383 Barracuda pulleys [Re: barracudadon383] #1684788
10/12/14 04:00 PM
10/12/14 04:00 PM
one of the sites that sells pulleys has a spec (od/height/# of grooves) for them I believe. I saw it but I dont remember where it was. You might check Mancini etc If you know what you need I have some
