Re: 28x10.5 tire guys rim ?
[Re: all spooled up]
#1684003
10/09/14 07:46 PM
10/09/14 07:46 PM
Posts: 4,068 Mo.
racerx
Mo.
that's the size I have 12 inch rim
same here.
[Re: 6PKRTSE]
#1684006
10/11/14 12:42 PM
10/11/14 12:42 PM
Posts: 1,550 Michigan
Kiddart
I run 8" can someone show a picture of a 28 x10 on a 12" rim? the tire section is only 11.2"? why a 12 inch rim?
Thank you Kiddart
[Re: upnover]
#1684008
10/11/14 10:50 PM
10/11/14 10:50 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
the wider the wheel the more air you can put in it so then you can put more power to it. I run 12" wide with 12lbs of air
BB, TT5,Procharged 3300lb Street Car 4.79/154
