Torsion bar removal tool..where to order for overnight? #1682910
10/06/14 11:46 PM
10/06/14 11:46 PM
Texas
carcrazyguy Offline OP
Texas
Anyone happen to know somewhere I can order a T-bar removal tool and have it shipped overnight? Classic Industries is out of stock. Jegs and Summit don't show them so???? Any ideas?
Re: Torsion bar removal tool..where to order for overnight? [Re: carcrazyguy] #1682911
10/06/14 11:54 PM
10/06/14 11:54 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
PM sent
Re: Torsion bar removal tool..where to order for overnight? [Re: jcc] #1682912
10/07/14 12:26 AM
10/07/14 12:26 AM
Texas
Texas
PM sent
And returned... Thanks for the offer! We are trying to get a car together for a show this weekend. I did not plan on tearing it apart but spotted a few things that really needed to be done before we try to drive it very far.
Re: Torsion bar removal tool..where to order for overnight? [Re: carcrazyguy] #1682913
10/07/14 12:34 AM
10/07/14 12:34 AM
Georgia
72440CUDA Offline
72440CUDA  Offline
Georgia
Re: Torsion bar removal tool..where to order for overnight? [Re: 72440CUDA] #1682914
10/07/14 12:36 AM
10/07/14 12:36 AM
Georgia
72440CUDA Offline
72440CUDA  Offline
Georgia
Re: Torsion bar removal tool..where to order for overnight? [Re: 72440CUDA] #1682915
10/07/14 12:37 AM
10/07/14 12:37 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
^ i like it!
Re: Torsion bar removal tool..where to order for overnight? [Re: 72440CUDA] #1682916
10/07/14 12:46 AM
10/07/14 12:46 AM
Texas
Texas
Will investigate that option!
Re: Torsion bar removal tool..where to order for overnight? [Re: carcrazyguy] #1682917
10/07/14 12:49 AM
10/07/14 12:49 AM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
sure i'd like to have a TB removal tool too, but since i don't and never think about it till i need it the very next day, i sure wouldn't overnight it. i just cant believe its *that* useful.
two bolts on the LBJ to knuckle, one on the strut to the LCA, LCA pin, swaybar links if you have one, and beat on the LCA to drive the TB back With urethane LCA bushings, dont even bother with the LCA pin. a scrap 2x or in my case a piece of oak floor, works well to drive the LCA.
or i have absolutely no idea what im missing... depends how often you're only under the car to swap a TBs i guess.
Re: Torsion bar removal tool..where to order for overnight? [Re: Trojmn] #1682918
10/07/14 01:09 AM
10/07/14 01:09 AM
Texas
Texas
Well I am trying to get a car ready for a local "once a year Mopar only" show. Did not plan on tearing the car down but found a few things that needed to be addressed. So.......
My brother just sent me a message that he made one from a piece of iron and 2 u bolts. So it looks like tomorrow we will test it out!
Re: Torsion bar removal tool..where to order for overnight? [Re: carcrazyguy] #1682919
10/07/14 11:31 AM
10/07/14 11:31 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
FWIW
Re: Torsion bar removal tool..where to order for overnight? [Re: carcrazyguy] #1682920
10/07/14 11:32 AM
10/07/14 11:32 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
You don't need no steenking tool! Try this. Back the adjuster all the way off, pry the adjuster lever up, knock it down, repeat a few times. Notice how much travel you get out of the adjuster lever? Go about half of the travel. Back the lower control arm pin nut off like 1/8 to 1/4". Whack the nut end with a mallet. The bar should just slide out. I came up with this in a wrecking yard pulling off some control arms and it has worked well since.
Carl Kessel
Re: Torsion bar removal tool..where to order for overnight? [Re: CKessel] #1682921
10/07/14 02:02 PM
10/07/14 02:02 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
And since this car was just put together recently the T-bar might just slide back by hand when you back the adjuster off and take the clip out.
Re: Torsion bar removal tool..where to order for overnight? [Re: autoxcuda] #1682922
10/16/14 02:04 AM
10/16/14 02:04 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
My cheap, maybe $5 tool from a piece of stock and hardware from Depot...
Re: Torsion bar removal tool..where to order for overnight? [Re: carcrazyguy] #1682923
10/19/14 01:27 AM
10/19/14 01:27 AM
NJ, USA
bill440rt Offline
bill440rt  Offline
NJ, USA
I cobbled up this thing today out of stuff I found lying in my garage: a piece of 2x4, a U-bolt from an exhaust clamp, & a piece of heater hose. Worked like a charm.
Re: Torsion bar removal tool..where to order for overnight? [Re: bill440rt] #1682924
12/04/14 01:03 AM
12/04/14 01:03 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
One the lower control arm is disconnected. Prybar between the lower control arm and k member will for the arm back, along with the torsion bar.
For bars seized in place. Use soft metal, like a 3/4" stock of aluminum bar. Hit the bar forwards to get it moving.
