No ethanol added pump gas #1682027
10/04/14 09:12 PM
10/04/14 09:12 PM
Upstate NY
Bigcube Offline OP
Bigcube  Offline OP
Upstate NY
I just found no ethanol added pump gas localy, too bad it's 91 instead of 93 I think 1/2 and 1/2 with some VP should be good winter storage gas.
Would an engine really notice 2 octane points? Would be nice to run the 91 straight but I only tested with 93. I'm thinking it might be worse than just 2 points lower as far as detonation resistance because of the no added Ethanol, what do you think?
Re: No ethanol added pump gas [Re: Bigcube] #1682028
10/04/14 09:24 PM
10/04/14 09:24 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I have 93 octane pump gas and 93 non ethanol both available to me here. The non ethanol version makes more power when jetted correctly and can withstand more timing before showing signs of detonating.
I would try it, bumping your timing down a couple decrypt start and see what it likes. I usually have to bump up a couple jet sizes over non ethanol fuel when going to E10, so keep that in mind also.
Keith
Re: No ethanol added pump gas [Re: Bigcube] #1682029
10/04/14 09:45 PM
10/04/14 09:45 PM
Az
Crizila Offline
Crizila  Offline
Az
In the late 60's I worked in an automotive research lab that had a knock lab attached to it ( single cylinder engines that you could raise and lower the CR while the engines were running ). Yes, even 1 octane # change can cause detonation that is audible.
Fastest 300
