EBC brake pads #1680841
10/01/14 11:09 PM
10/01/14 11:09 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
will these pads provide improved braking as claimed?
Re: EBC brake pads [Re: can.al] #1680842
10/02/14 03:40 AM
10/02/14 03:40 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Compared to what? What are you running or planning on running? I've heard some good things about them but they have different color codes. I have no idea which is which.
Re: EBC brake pads [Re: MuuMuu101] #1680843
10/02/14 09:08 AM
10/02/14 09:08 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
i agree.. compared to what..
i put the ebc reds on my mustang. it does stop a lot better than whatever was on it before. but damn the amount of brake dust on my white wheels is nuts.. and they said the red were low dust lol..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: EBC brake pads [Re: abodyjoe] #1680844
10/02/14 09:17 AM
10/02/14 09:17 AM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
I have the "Yellow stuff" with my Viper calipers. They work OK cold but much better hot. Dust is not too bad.
Re: EBC brake pads [Re: MuuMuu101] #1680845
10/02/14 10:19 AM
10/02/14 10:19 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
O.E. pads
Re: EBC brake pads [Re: can.al] #1680846
10/02/14 11:32 AM
10/02/14 11:32 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
The question is kind of open ended.
What is your goal with the car?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: EBC brake pads [Re: AlexP] #1680847
10/02/14 07:07 PM
10/02/14 07:07 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
wow,i think you guys are reading way more into this than is there.
This is just a restoration to be driven as i see fit any given day.
Just wondering if the claim to improve braking and easy on rotors is
true over an O.E. pad?
Re: EBC brake pads [Re: can.al] #1680848
10/02/14 07:11 PM
10/02/14 07:11 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
If you're driving it like a perfectly restored car, then any pad is fine.
EBC has several different grades of friction material to respond to the needs of different cars.
I wouldn't spend the money on an expensive pad if you're not going to have modern tires and suspension.
Put a good Raybestos or Wagner Semi-metallic pad on a restoration type car and be done.
Re: EBC brake pads [Re: AlexP] #1680849
10/02/14 07:57 PM
10/02/14 07:57 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
I agree, a friend has a 69 Mustang and it broke much worse with EBC pads, they weren't getting enough heat in them on the street to work properly...
Re: EBC brake pads [Re: AlexP] #1680850
10/02/14 08:30 PM
10/02/14 08:30 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..so the next time i'm driving and a normal or pannick stop is required their claim to stop quicker and be easier on the rotors is not actually true?
Re: EBC brake pads [Re: can.al] #1680851
10/02/14 08:47 PM
10/02/14 08:47 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I would rather run Hawks. Although I do have EBC's on trucks and SUV's. The Yellow stuff are squeakers.
Mopar to the bone!!!
Re: EBC brake pads [Re: can.al] #1680852
10/03/14 12:40 AM
10/03/14 12:40 AM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
I don't know which "color" of their pads are best for street use. My buddy switched to Hawk and the car stops much better...
Re: EBC brake pads [Re: Tomswheels] #1680853
04/05/15 03:20 PM
04/05/15 03:20 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
I just installed EBC yellow on my daily Dart today.
I had Hawk HPS on the car before but wasn't that impressed (anymore) with them.
Could be I need to step down one size in MC diameter from the current 1-1/32" to 15/16".
Braking is just fine, even at mild speeds but I just can't apply them enough to lock 'm in the front.
Hoping the Yellow's have a bit more bite before I start playing with MC's again.
Re: EBC brake pads [Re: BigBlockMopar] #1680854
04/05/15 05:59 PM
04/05/15 05:59 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Please report back your findings.
Re: EBC brake pads [Re: autoxcuda] #1680855
04/06/15 06:40 AM
04/06/15 06:40 AM
The Netherlands
The Netherlands
FYI, I also installed new fresh discs in the process, keeping the orientation of the old HPS pads respective with the old discs.
Re: EBC brake pads [Re: BigBlockMopar] #1680856
04/06/15 06:49 AM
04/06/15 06:49 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do you notice any braking differences so far?
Re: EBC brake pads [Re: autoxcuda] #1680857
04/06/15 11:52 AM
04/06/15 11:52 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have ran the Yellows before and they work OK but were noisy.
Re: EBC brake pads [Re: can.al] #1797155
04/07/15 09:46 AM
04/07/15 09:46 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
There's really no way to know.
First - Some of the old pads were really good, such as ones with Raybestos lining BSI 452 (rated FG). The edge lining markings, if the manufacturer provides them, will indicate if linings are in the same ballpark. But its only ballpark.
Second - its temperature dependent. A lining that grips well pulling an early SHO (known for undersize brakes) down hard from 75 mph may not grip well pulling your viper out of your driveway at 30 F.
Third - How well a lining works is also driver and system dependent. Some drivers like an instant response some like a more progressive one. A power brake system with a grippy lining in the front might feel uncomfortable for some drivers. For example I found Raybestos's "Professional Grade" pads semi-metalic for my wagoneer to be a little too grippy and I'm still getting used to them. Now if they had a similar lining for the rear drums, or I didn't have a power assist - I bet the balance would be better to my taste.
Re: EBC brake pads [Re: can.al] #1797404
04/07/15 02:24 PM
04/07/15 02:24 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I ran the yellow stuff on my wife's jeep, she complained about the squealing but they would put you through the windshield. I wound up putting in some basic ceramics after they wore out, now I have to stand on the pedal to get it to slow down. She like it better because they don't squeal. I may just put dual piston calipers to get it to brake better off of a Grand Cherokee.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: EBC brake pads [Re: astjp2] #1797445
04/07/15 03:00 PM
04/07/15 03:00 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
See if you can buy the pads with the same "Professional Grade" lining as the D52 pads on my GrandWagoneer. Lots of grab, friction rating FF, semi-metallic, no-squeal, reasonably priced.
Here's the details.
Mfc: Raybestos
Pad shape: D52
Edge Code: BPI-LC-FF
Mfc Desc: Professional Grade
Part Number: PGD52M
Type of Lining: Semi-Metalic
The G Wagoneer only has a single pot sliding caliper - nothing special. Yesterday I was carrying close to a full load (about 900 lbs) and it braked well, only got the linings hot enough to smell once. Of course I allowed for extra stopping distance and all the usual precautions with extra weight in the back.
