trans wiring #1680399
09/30/14 08:34 PM
09/30/14 08:34 PM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
need help with trans wiring. under hood fire need to rewire. 87 Dodge trans plug has three wires Brn/Yel, Vio/Blk, White. it also has a Blue/White in the harness with a post plug on it.can someone please tell me where these wires connect to. THANKS I have repair manuals, and I've been to the library,can not find this plug
Re: trans wiring [Re: 72sat] #1680400
09/30/14 09:30 PM
09/30/14 09:30 PM
3 wire trans plug. I'm assuming the center pin/wire is the NSS ground & if the pin has continuity to ground in park/neutral then it is that. The 2 outer pins are 12V input and the other goes downstream to the white reverse (backup) lights in the rear bumper (area). See if those 2 pins on the trans have continuity (to each other/not to ground) in reverse then if so they are that
Re: trans wiring [Re: RapidRobert] #1680401
09/30/14 10:25 PM
09/30/14 10:25 PM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
THANKS RR
